True, however picking up some sIut in your skyline doesn't really fall within the ambit of that section now does it? :whistling:
No sir, it does not :whistling:
Jeremy...in Victoria it's 16 and over unless you have an existing relationship of authority with them / they are in your care...in which case it's 18 and over...look it up...
Happy slumber party :thumbsup:
Jizzy... her 16th birthday = go for gold in Victoria, assuming she is just a mate of yours and you aren't her singing/guitar/posing coach or some shit. Don't let anyone tell you otherwise.
EDIT: Just kidding, don't listen to Birds, it's only legal if she has a friend and you invite me as well.
Haha f*ck yes!
I can't believe 16 year olds are legal though.. I drive past 5 high schools on my way to work and have refrained from even making eye contact with any of the older students. I've been missing out on so much! :P
Haha f*ck yes!
Had this year 10 at my sisters school this morning wave at me. She so wants my dick
Get in there fellas!
The chance of mine happening is about 90%, coz I've already half gone there and discussed the high probability of further action.
Mohsen got a wave. He doesn't even know the chicks name. And at the end of the day, it's Mohsen.
Who wants to place bets? :thumbsup:
Edited by jezza boii
shits gettin creepy fellas, unless your all a shit load younger than me.
sort yaselves out i mean really wtf you want with a kid? they cant even drive or drink..
:unsure:
1. Why do they need to drive? They can catch the bus to mine or get dropped off by mummy lol
2. Why do they need to drink? Although pretty sure 90% of 17 year olds drink anyway
We're talking about these girls being DTF, not going out with them.
And for the record, I'm 21.. and 17 is pushing it for me. But she's a few months off 18 so will let it slide.
Young = less time for gravity / other guys to have played with their bodies.
16 is age of cosent i sure as fk wouldnt risk it with anything under 18 though
Yeah, I have to agree with you on that note...some teenagers are very immature and vindictive...you never know when one might cry rape/assault for the sake of it.
Much to learn, you have :)
no shit. More than a little disturbing though. They're still kids...not to mention teenagers are annoying 0.o
Kids with developed bodies, boobs and fully functioning reproductive systems...hell yes. Annoying we can live with, it's only for one night LOL.
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
