real shit... check out this verse by R.A.
skiiiiiilz
i should also point out that unlike eminem and other fake ass rappers, that verse is recorded in a single take, not edited together, and he actually can do it live without miming
impressive though not really what i'm into. prefer a more entertaining kind of beat but each to their own :thumbsup:
Game better than NWA? Not even.
Rimon, ecu flash and mickey Ts = 11s in the new gt. Also want :)
tuff tuff i'm really liking the new fpv/hsv range definately up there if i'm ever in the market for a big quick 4 door
No. Because I'm not gonna say. Just putting it out there to create suspence.
Now I'm off to cry in my car over what I could of had.
There is no suspense really cos nobody actually cares that much
I'm left wondering what my post count would be if Alex wasn't around to beat me to it.
about 3k higher?
when i first joined i saw your post count and thought "holy shit"
Edited by Mohsen
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
