How do you know those guys have had those cars paid for by their parents? For all we know the guy could be an astrophysics whizz who's banging some hot Asian beaver from the student accom block.
Because he's at uni, so I doubt he makes enough to afford it on an income from Maccas...But I doubt he works at all anyway.
Might be checking out Squires Loft tomorrow..
Albert Park? They have some damn quality steaks there. Not sure if they have cous cous though. :P
As per what Dezz said.
No 20-22 year old @ Uni has that type of money.
Fair enough if the guy was an entrepreneur or something and @ 20 got onto a good deal - I'll pay that as respect.
But you can spot a student mate and there is no way all of them have got onto a good thing (which are indo or asian, not being racist, just fact)
Very, very safe bet that the parents have bought the car when someone that young steps out of a 200k+ car - particularly the international students, as it does cost a lot to send someone over here to study and in many cases the parents are loaded. It might strike up feelings of jealousy...but these students are the .001% of the population back home who can actually afford to do it. So they are even luckier than you think they are lol.
I'd hedge on less than 5% of the 21 year olds driving 200k+ cars having bought them for themselves. Even then, what further percentage of those students started life in the gutter?
His house is on the market for around 650k... When I walked in and my friend (the real estate agent selling it) told me he's a student, first thing I asked was if he's Asian... And he was lol
So what if mum/dad bought their son an expensive toy? Good for them for not wanting their kids to suffer to get what they want in life. Let's hope he does the same for his kids...
Only those ones in Dubai sliding lambos. Not ones like you lol
HAVE to visit that place sometime before I die.
And now off to trade school. Fml
Edited by R-SPEC
I agree to an extent, if your parents want to take care of you and they can afford it then fair enough... but you've got to draw the line somewhere, i wouldn't call it 'suffering' to not have a Lambo at 22 years old lol
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
