here's mine, not one being deserved lol....
Blitz Note Added 06 October 2009 - 01:28 PM
Added to warn level Failure to follow forum rules - Comments made in sale thread:
Quote
i would rather gouge my eyes out and then blindly stab at them with a rusty fork...
PranK Note Added 01 June 2009 - 10:08 AM
Added to warn level Sexist comments made in thread - http://www.skylinesa...0786.html&st=20
dan_the_man Note Added 04 November 2008 - 04:15 PM
Added to warn level Defamatory remarks made towards businesses or individuals will not be tolerated on this website
1, the dude was selling phat pants... PHAT PANTS...
2, suggested to a female member that naked pic's would help with her topic (as was the style at the time)
3, mentioned that nengun is slow, and that their advertisement to buy into thier business of "excellent customer service" was lulz worthy
Told some cock sucker that his lancer does not beat vn ss's etc.
The warnings were still coming as you can see by the email notification in the bottom corner.
Got a year holiday after the 19 or so warnings, which woulda put me at about 200% lol
this guy lives in point cook and jess is his agent...
I see, yeah, don't know the guy.
But Jess, I do :)
Hope she is a good agent...
Tossing up dyno day but kinda cbf driving that far
Lazy kent :laugh: It's not that far.
wtf is this, surely I'm not the only one that thinks this looks stupid.. sure the rims are nice but thats about it and ruined by stupid camber anyway.
It is a Nissan S13 Silvia with Honda Odyssey head lights, called the "Odyvia".
Runs a L28 with triple Nismo Solex 44 HH carburetors.
