Need a memory card for my camera but have no idea what to get. Am technologically retarded. Anyone here have any recommendations that would like to share? Will be taking hundreds of photos. Cost not an issue.
Think of it like this, the average decent quality picture is about 5MB so for every 1GB you get in your memory card is roughly 200 photos you can fit, some of the better quality (higher res) cameras will take photos about 10MB each so obviously that would be 100 photos per 1GB.. get a 8 16 or 32 GB card.. will be sweet :thumbsup:
i see no purpose in taking 5mb photots that are like 4096x2048 though
its just too big for anything useful
unless you have a 25,000 pixel printer at home
pics that are like half the size and half the rest would be just as good
and youd be able to take twice as many
Take me on as a first year and pay me commercial EBA rates. Problem solved.
fine by me but he's being a tight arse lately. Have mentioned you to him once or twice before, no go...
Have you thought about taking up different trade? If I was to quit for whatever reason I'd take up plumbing mainly coz plumbers pwn sparkies money wise. Job's a bit dirtier but meh.
Yeah I always fiddle around with file size, even if you are on a holiday and realize your card is half full.. can just adjust your file size - completely agree 4k + resolution is a bit ghey. (unless its actually your profession or something)
Oh hai! What were you in?
my discgraceful bone stock R32 i was in left lane going straight towards eastlink spotted the cube out of the corner of my eye and was like what the!... ohhhh a cube haha, ive been looking at getting one theres only one for sale in the country with a sunroof and cant get hold of the guy lol :( 1.4L, sunroof, autech kit, 5 seater, some gayass rims
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
