My mate had a motorcross track in his backyard...and a big f**k off digger thing to build the jumps/table tops etc...
Snapped the frame of my Pee Wee 50 there one day, welded it up and sold it for $600 (my mum bought it brand new for my brother for about $200 18 years prior)
make it stop
That guy has to be the ultimate troll. No way is that vid serious.
entry price?
dresscode?
hot girls?
15 if your on a list
whatever the f**k you want really, last week was jeans and a t, this week ill be fromal spec, but with crutches and a moon boot ;)
many many dubstep broad minded persons to be had
I'm pretty sure a nice T will pass at Jet Black, dress code was never that strict when I used to go. And we don't have to stay there if it's shit or if you wanna try elsewhere, was just a suggestion :)
I'm telling Alex to dress to impress for his own good :P Last time his wrinkled shirt made him look like a mass bogan lol.
I'm not sure whether to go for the wog look (tight white T and a cross) or wear a nice collared shirt with the sleeves rolled up. See how I feel later.
Probably meeting at Adam's around 7ish. So be prepared around then :) Will confirm times when he finishes work though.
Not every thought in your head should be reproduced verbally/electronically etc
You ain't gonna get poon typing phaggotry like that
lol I'm going wog tonight. Minus the cross.
Are you wearing white? Coz if you do, I won't :P Hate having matching outfits.
7pm it is. You have the address ;) I will shutup now because apparently it's offending Alex.
Hope to see you tonight Ric. Even if we just run into eachother on chapel for a quick chat.
wonton stock is a simple soybeans + pork bones + soy sauce + dried cuttlefish.
as for wontons.. i can't fold them properly!
That's only the easy part of the stock. :D
add in a few other little things and it becomes something totally different.
pfft, wontons are easy to fold. xD
But you tend to see most restaurants cheap out on the filling! >:|
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
