That guy has to be the ultimate troll. No way is that vid serious.
I'm not so sure..
Volt
Free
Anything goes
Volt entry is actually something ridiculous like $15...Should be free because it's a hole, but people do actually pay to go in there...
Not every thought in your head should be reproduced verbally/electronically etc
You ain't gonna get poon typing phaggotry like that
I like this guy. :cheers:
I appreciate it man, but I don't really need advice on "how to get poon" :thumbsup:
Also not too worried about what girls on here think of me :P
the ones who things up the most are usually in reality the exact opposite. :whistling:
its like theres pretend rich who brag an shit then there is real rich who dont say anything but you just know they wipe there ass with silk
wiping asses is for peasants.
Bidet and douchettes brah.
Shan where you been homo.
Also
fight fight fight!
Rimon v Jeremy
Why...
Kunts shoot down 11ty ducks and it's all good
Kunts stone a swan and it makes the front page of every paper
Racism towards the ducks.
Why?
I tend to agree with this. I just don't mention money coz I'm a poor kent :P
Anyway, I'm off to get my drink on with Birds and crew. Have a good night people!
Edited by jezza boii
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
