Werent you the one saying it was gay the first tome he wanted to do the roof lining?
I believe he thought it was gay when the f**ked up patterns were brought into it..
I don't mind normal plaid.
What moh said plaid IF done right is sweet
he comes to you, charges a little extra but its worth it
never had a stud he hasnt gotten out
phew.... found his card too lol
Damian de Yong
0419 507 633
sweet thank you! :D
Can you get the bolt out with the turbo still in the car? Same thing happened to me (too lazy / didn't think to use WD40) and I had to have the turbo removed.
My advice to you Anf - drive around with 5 bolts in for now, then as soon as you can, buy a Garrett kit. You won't have to bother getting bolts and shit removed from your poxy stocker turbs :thumbsup:
most likely this will be the route i take, depending on $$$ of course :P - but if i end up just hiflowing ill prob try get thread doctor sooner than later!
decisions decisions
thanks guys :D
Shan is just upset that every car he has owned has been a beat up piece of shit. Including a golf that he wants to do up with plad hahahaha fkn fag currypuff
at the end of the day, my beat up cars look beat up cos I beat them up.
your car looks like a bag of dicks cos you love yourself a good bag of dicks?
:P
come at me bro.
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
