MR is different to RR derp derp derp
http://en.wikipedia.org/wiki/Category:Rear_mid-engine,_rear-wheel_drive_vehicles
mind you, the only car in that list that handles like a bag of dicks is the MR2. Mostly thanks to its transversely mounted engine, which is exactly what happens when you drive a civic really fast in reverse while facing the wrong way.
Lol, I love the amount of shit given to MR2s, but how many of you guys have actually been in one?
It handles beautifully. Never understeers. Never oversteers. Ever. Drop the clutch in the wet, sticks like shit to a blanket.
Can't say the same about the GTS(T)'s I've driven. No point arguing it here though, everyone is too closed minded.
my brother and i test drove a few when he was looking at them
noisey, sketchy in wet, understeered.... he ended up buying a v35 instead, wise move
turning onto sharpes rd in tullamarine once we saw a mr2 that lost it around the bend there, only car that i know of to ever lose it there
i would rather a gtst the weight is on the front for turning with the engine, and the rear wheels will have traction depending how heavy ur foot is
Jeremy I can guarantee you have never driven your car hard enough to oversteer/understeer lol
A lambo and a Ferrari will understeer and oversteer. I don't think Toyota put more r&d into a little supercar mockup 15 years ago then lambo and Ferrari do right now
fuck off. I've owned 2 MR2's. the first was a supercharged AW11 while you were still suckin on your momma's teat and then when the 15 year rule kicked in back in 2005(?) I bought an SW20 GTS. SW20 handled like a bag of dicks, even with all the TRD suspension on it, and I actually preferred the AW11 compared to that cramped up excuse for a shopping trolley.
Toyota totally bitched out with the second gen MR2. First gen was half decent, simple suspension layout, simple engine layout, no spooling of turbos or any predictability issues due to non linear power delivery, was awesome to drive on the limit and through the twisties. Compared to that the SW20 was just made for fat fucker white guys in the UK and US who couldn't afford a 911.
dude if you got 40k get a sweet ass daily and a sweet as weekender i mean you could split 50/50 and get 33gtr and like i dunno a bommodore, or vw polo (see homo spec) heaps of otpions. i'd be gettign something with towing capability myself.
thats what i'd be doing i dont see imports as dailys anymore its just not worht it.
edit: should have read ssxrichos post first lol. Spot on though.
well i forgot to add one thing i have no room for 2 cars at the moment lol. the first thing that came to my mind was 2 cars but i really cant do it yet. And id never own a VW i dont like any of them at all.
    • Just as a thought, if it's in neutral, thats your drive line disconnect, not the clutch. Clutch slip at the dyno with pedal fully out, is actually adding a second disconnect. So it's not a clutch issue if you're in neutral. Just a bit of friction dragging the output around while in the air.
    • The HG high flow is excellent, and costs about the $$ you're talking about. But it, and probably every other highflow, uses a diffeent core than the original turo, and the original Hitatchi core is quite long. So, I think it is inevitable that there is likely no such thing as a highflow that just "bolts on" with no other effort required. And the same is likely true for HG's outright replacement "bolt on" turbos (the ATR things). And the same is likely true for anything similar from elsewhere. I have no idea if the cheap Chinese/Taiwanese complete turbos from eBay/Temu/etc are as bolt on as they claim. I mean, they claim the bolt onto the NAs as well as the turbos, and we know that can't be "bolt on". But it wouldn't matter because I'm not buying a $169 4 psi turbo for anything other than a paddock basher.
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
