maybe jizzy boi has an STD to give you
:rofl2:
Not really. I flog myself @ work, treat my body like shit (ie i dont sleep for 2 days @ time).
I dont think its really mobid. More so realistic. I'm having fun doing what im doing, so i dont really care for much more :)
Ye. IM closed... I'll get out there and pack it during the week on Wed for ya mate. :thumbsup:
yeh sweet just wanted to make sure you got the $$ no hurry to send
you wash your hands after floggin yourself?
hahaha
Only if I'm doing it in the work dunnies. Elsehwere, dont really care.
:ermm:
Few hands later I had AK in the big blind, waited so I could get some money out of it.. My dad bet $1800, cousin and uncle called so I went all in with about 9k. Dad and cousin folded, uncle called and turned over pocket jacks. Hit the king on the river.
Few hands later again in the chip lead, pocket 7's bet 5k, old man went all in with about 14k. Called him, turns over pocket kings. Flop was something something 7. River was a f**king king. Sickening.
Went out next hand with A7 suited.
Sickening
Sickening
I hate that sort of shit. It never happens on the turn card, it always seems to happen on the river which makes it burn that much more.
    • Well, this is probably where a wiring diagram and a multimeter come into play.
    • I can say to anyone thats doing this; having done a number of R clusters; just be careful if its an unknown cluster.  It takes a bit of force to pull up; but if it feels excessive then its probably stuck. I've had this and pulled the entire hair spring out; and I can tell you; its not easy getting the correct spring replacement with the correct inner diameter and winding. In my case someone had used some sort of adhesive to stick it to the spindle and it pulled the whole spindle out; which the force seperated the hairspring from the spindal and caused it to deform.  You may have to clean it (IPA); or in my case if i'd known i should have used some sort of solvent on it.  Also check out Cruizin Central on eBay. He does all sorts of dials; and you can email him with any custom designs you want. So if you want like certain logos etc...he'll send you a mock of what it will look like then you accept the order and he'll take care of the rest. Fantastic dials and he can do basically any design you want.
    • Have you confirmed its the actual axles? Also the wheel bearings that mount on the hubs to hold the axles wear out. I replaced mine as they got play in them. It sorted my play issue.
    • Ive converted a few clusters for the R33 with 320km/h dials. On the back there are some pads which can be bridged or unbridged (using solder or wick braid) to calibrate it. There is one bridge which is for MPH <> KPH; and there are combinations of bridges to offset it. There is probably a diagram  For example; this is my conversion for a 180km/h dial to a 320km/h dial (I put custom GT-R dials on it with the GTS25t layout) If you have J2 soldered (assuming the S clusters have a similar config to the R clusters); you may need to remove that solder
    • Back on topic 😉, these are some of the notable pages from the booklets that are supplied with each weekly parts update. I never knew the BNR32 test mule car had an S13 Silvia front end... *Edit: On closer inspection the test car still had the R32 body, but only the front end had Silvia panels etc.
