Maybe he just wants to keep talkin to ya Juliette ;)
I must come across as too nice and friendly when I'm selling something. It hasn't just happened with selling cars, I've sold parts then ended up with 10 phone calls with questions afterwards. I've gotta start being a hardarse bitch from now on, might help?
Not sure why your complaining these people have paid good money why shouldn't you answer a few questions not like they are breaking ya balls everyday if I bought something and Hana few questions I'd expect answers
Tens pushing it but 3-5 is fine
If you regularly wash stainless exhaust tips they stay shiny...even the cheap stuff my Varex is made from is still shiny because I was it everytime I wash the car. My friend's Varex on the other hand, he let it go for a year and there's no coming back from that build up.
yeh my hks hi-power cleans up nicely except for the titanium tip, must not have been cleaned properly in japan and even steel wool cant clean it perfectly
Use quickleen stainless cleaner. We sell it at 30 bux per kg. Non corrosive, lasts for ages, not very messy. Acts like a cut and polish. I'll bring some on the next meet.
Cleaned up the exhaust on the r32 well.
On another note, my mate vacuum sealed my money hahaha. (he's a butcher, dropped the car to his bro and went to get teh $)
Took ages to open
Yeah but some of them get creepy after they're finished with questions related to the product. As far as I see it you ask questions before you buy a product, not after it. I certainly don't pester people I buy items off after I've received the item.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
