Maybe he just wants to keep talkin to ya Juliette ;)
I must come across as too nice and friendly when I'm selling something. It hasn't just happened with selling cars, I've sold parts then ended up with 10 phone calls with questions afterwards. I've gotta start being a hardarse bitch from now on, might help?
Not sure why your complaining these people have paid good money why shouldn't you answer a few questions not like they are breaking ya balls everyday if I bought something and Hana few questions I'd expect answers
Tens pushing it but 3-5 is fine
If you regularly wash stainless exhaust tips they stay shiny...even the cheap stuff my Varex is made from is still shiny because I was it everytime I wash the car. My friend's Varex on the other hand, he let it go for a year and there's no coming back from that build up.
yeh my hks hi-power cleans up nicely except for the titanium tip, must not have been cleaned properly in japan and even steel wool cant clean it perfectly
Use quickleen stainless cleaner. We sell it at 30 bux per kg. Non corrosive, lasts for ages, not very messy. Acts like a cut and polish. I'll bring some on the next meet.
Cleaned up the exhaust on the r32 well.
On another note, my mate vacuum sealed my money hahaha. (he's a butcher, dropped the car to his bro and went to get teh $)
Took ages to open
Yeah but some of them get creepy after they're finished with questions related to the product. As far as I see it you ask questions before you buy a product, not after it. I certainly don't pester people I buy items off after I've received the item.
    • Put a fuel pressure gauge on it. Replace the turbos. Probably completely separate issues.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
