What the fuck?
You ain't seen that before? That was one of your turns Ash. But you didn't turn up so we played for you.
That was awesome Birds!!! Pull out that dance move next time we go out! :thumbsup:
Btw, in regards to your event; Friday is going to be a bit difficult but I'll try and get down there. What are you doing on the Saturday? Coz I'm pretty keen to celebrate with you.
Haha there's never enough room to do that stuff at crowded clubs, I do love trick moves though.
No stress...it's nothing special, just something my friends put together. Thought I'd let ya know in case you and the regulars hadn't planned anything for Friday.
haha :D
Nice should be happy with it Mo - Just dont waste too much money on it, all in moderation :) a 34GTR will prob be cheap by the time you get off Ps :P
Fucking hell, Rota are the biggest wannabes of all :laugh:
The first set of wheels are copies of TE37V's, designed to suite older model cars, like so...
And 2nd set are Nismo LMGT4 wannabes.
But yeah, if Mohsen does not wanna spend too much on it, just go for Rotas.
Plenty of ppl rep'em in the USA.
Hmmm don't like 5 spokes Tho. Prefer multis
I think 5 thick spokes suite the R33 due to it being a large looking car.
Needs a tough looking set of wheels, IMO.
But then again, look at Billy's... Looks nice.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
