dunno where that is lol
this guy trains at fenix point cook his afkn beast always has green wrfl shorts on tatts on shoulder/arm fit as all hell guys an animal wouldnt wana play against him :wacko:
Green shorts, probably Spotswood...Yellow lettering?
Probably play him in 3 weeks..lol
Dragged some VT clubby after lunch today - was lols. (to the speed limit anyway)
Lol asif bother with that.
Had some dumb shit in a black r33 go at me. Lets just say he was waaaaay back. Comes and asks me my power at the next lights and claimed he has 280rwkw. I just looked at him and went. "no mate you don't. This is 280rwkw." his passenger was pissing himself laughing.
and LOL @ 3/4 filling a tank for economy... All of what, 5-8Kgs of weight? hahaha... i cannot fathom...
You'd get better gains running 4psi more in the tyres.
And filing up 3 times a week = you be paying more @ worse times = less economical
That blokes a f**kn machine!
Try driving a 4cyl car with barely much more than 200kw, you feel the difference, trust me!!
Like if I have a 100kg friend in the car the bloody thing just doesn't move. Not like my ZX when I could have 4 passengers and still get pushed back in the seat a bit.
actually ther arnt all bad
evo goes all with car weight of 1400kg and 205kw
even with passengers
I doubt a little tuna can car has as big of a tank, i bet its single figures!
Im waiting for the next idea of leaving the spare tyre/jack out for weight reduction.
Or like that other idiot in the Skyline Discussion who removed the A/C to increase fuel economy/lighten the car LOL...
I said 3/4 is the max I've ever put in. It normally sits around 1/4. I put in $30 when it gets close to empty.
Also if it's expensive then I'll only put in about $10 and wait for the price to go down. I only put in $30 if it's cheap.
Weird system but it works for me.
EDIT:
Lol @ tyre/spare jack..... I removed my spare tyre and tool kit the day I got the car :P
Edited by jezza boii
i bet your fuel system likes all the shit floating around from 1/4 tank too
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
