I have 3 goals in life, a GTR, to impregnate a female human (eventually) and to prove you wrong
one out of three ain't that bad i suppose.
It is my opinion that any skyline is made better by virtue of having 4-doors with the singular exception of ADM R31s :).
yes but ALL skylines are made worse by virtue of having a Mohsen.
ADM only have 4 doors though. I was tossing up between a turbo Passage and my 33. Pillarless <3
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
