I dunno about you guys, but I can't buy or consider buying performance/sports cars I've beaten in run ins with my near standard R33. They just seem to lose their appeal after that. MPS, XR5 Turbo, Golf GTi, Cooper S, list goes on. Makes me think, why bother buying one of these when such an old car will just do away with it. Not saying the new cars have to get faster and faster, but they better have something special to offer and above a 15 year old Skyline that's all. Aesthetics and fuel economy maybe? A better feel? Not performance though...
I like the 1 series :(
s3 33 GTR seats the best amirite? :P
I agree Hamish, for a track car you would want something with a bit more 'bucket' but at the same time if your not a big guy they seem to be fine for a little track work / comfy for the street a good balance IMO
34R / Eastbear seats are ok for track work. They allow you to still have feeling in your ass once you arrive at the track as well.
32/33 are almost useless as the shoulder wings are not large enough.
And get some KU31's they own in the wet from all reports. They cost more than KU36 for a reason....
How is your car now Hamish that is sounds like s Saab wagon?
Also youtube'nes right here
didn't work
It's cause your link was wrong
[video]http://www.youtube.com/watch?v=KuLvVpHcOcQ[/video]
It'll work with that... The youtube address you had somehow was wrong, so hence it wont register when being embedded.
Strange, copied it straight from youtoob
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
