my professors (18x9.5) are just on 10kg
they aint heavy wheels
call him and tell him your a mate of mine.... then watch him drop $50 of the price like that... LIKE THAT!
whodaman?
I had about an inch on you, now with 17's its about an inch and a half lol... Lets not go there!!!!
When I get back, ive got something in store for you ;)
are you sure..? haha when u get back july or soemthing?
Oh and alex, nah im not coming tonight haha. How was/is it? same shit or...?
didnt go.. was to warm in bed haha.. think it was usual shitttt been a bit better last couple weeks but a bit more attention too it seeems :down:
Yeah cool Shan!
If they want decent resale value, then yes... Yes they do :P
that aside, regardless of ur personal opinion of gtrs, they're still an icon. Kids grow up lusting after it and staring at it. Not that they don't at other skylines but it has a rep that's hard to shake. My bf's gtst makes 280rwkw and is bright orange. And it gets a lot of attention. But my stocker 190awkw gtr gets just as much awe as his does depending on the audience. First question when people see it... 'is that a REAL gtr??'
And his car as a 34 is still 40-50k 10 odd years on.
Case closed :D
Fuck I hate it when ppl ask that!
To the untrained eye, they can't see the wider guards and the GTR badge.
What makes it worst is, I don't have the OEM Spoiler and ppl just think it is a GTS-T.
Garage Cafe Audi S5..?
why don't you e85 tune it while you're at it?
in other news...
Regamaster induced boner:
:down::D
I like!
Well it turns out that the oil light was only on because the sensor is from the gen2 NA engine.. the gen3 turbo is completely different.
That's what the previous owner told me (after I just txted him about it).
I actually checked the dipstick this time and it indicates it's full haha..
BUT there is a pool of oil under the car (probably about 100ml). Could this be because I overflowed it? I only topped it up by about 100ml
Either I have epic failed or the old owner is lying.
so originally was a gen 2 NA engine ? and now a gen 3 turbo
why the engine swap?
Well the swap was done at 220,000km when the old engine was getting a bit old.
The gen3 is a much better designed engine. And well, obviously for more power!
Gen 2 NA = 117kw
Gen 3 turbo = 180kw (stock)
Mine would probably be over 200kw. Loving the power/weight ratio :down:
Gen 2 NA = 117kw
ah yeh fair call
yeah i knew they had more power, and they dont feel so restrictive up top cause they have better cams (brother was looking at buying one)
actually when he was looking he found a gen 2 with gen 3 engine we test drove in gladstone park, was red and paint work wasnt the best best
sounds similar to the one you bought
Guest
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
