car cost: $5600
suspension (coilovers, camber plates for rear, camber arms for front): $3200
wheels (meister S1's, anodized outer lips, powdercoated centers, new bolts, labour to take apart, put back together, balance): smidgen over $3000
fuck. i overshot the mark a long time ago.
then add:
OEM bodykit and front splitter
paint
leather reconditioning
burberry print headlining
OEM xenon headlights
Hella led tail lights
FFFUUU!
also, jizzy, bright fucking qualified audio engineer you are putting a $2000+ precision audio system in a car that's subject to road traffic noise, tyre noise, vibrations, interior rattles, engine noise, electrical feedback and poor staging. I bet you also try to find virgins in a whorehouse.
$4000+ actually :thumbsup: And I don't really listen to it properly while driving, only when the car is off.
While driving it's just ambient noise really. Sometimes I'll crank it to a ridiculous level if the gearbox whine is shitting me.
Really gotta fix that soon.
you listen to music in a car while it's off? wtf.
don't you get out and go wherever you're going? I'm sure you have a soundproofed room in your house to enjoy your tunes in rather than in the car?
I spend a lot of time just sitting in my car. It's like my little sanctuary :thumbsup:
But nah, most nights I'll go park at the beach with a chick friend, chill, listen to some tunes or watch a movie etc.
It's especially good in summer with the targas off.
And no, I can't do it at home. My bedroom is extremely small, crammed full of double bed and audio gear goodness :D
No soundproofing and my 2 younger brothers are in the rooms backing onto mine, meaning no noise after 7pm (homework / bed time)
So yeah, the car is great in that aspect. Just need to upgrade my battery.
or get comfortable with f**king in public places.
car is my sanctuary GTFO. lol. for srs?
Since when did I mention f*cking? :/ I will happily do that in my own bed.
And yes I'm serious. I'd sleep in my car if I could. I love it to bits.
really? you just listen to tunes and watch a movie in a car with a girl at the beach?
sleep in your car? wtf? don't you own an MR2? you can hardly sit in those things, let alone sleep.
Yeah, I did last night. Was pretty chill.
Besides, I have a girlfriend for all that kinky shit.
That's why I said "IF I could" :/
Passenger seat removed, you could. The footwells are pretty long. Replace the rear storage box with a pillow and you'd be sweet.
That's what I'd do if my parents kicked me out right now :) Cost effective living.
Edited by jezza boii
That's what I'd do if my parents kicked me out right now :/ Cost effective living.
there was a news article about some woman doin that with her kids in th epaper. y'all should get a place together.
Guest
    • There's restrictor pills in the stock boost control hoses. That's how they set the amount that was bled off and hence the "high" boost setting. The usual mod in the day was to remove it and send the "high" boost setting up to about 14 psi.
    • Thanks Duncan, that's the best info I've read. Furthermore after learning about the PCM programming side controlling the factory boost solenoid, the purpose of the solenoid is to "bleed" boost when pin 25 is earthed, thus allowing spring pressure in the wastegate actuator to overcome diaphragm boost pressure, thus closing or reducing the position of the wastegate flap creating more boost as the turbo is able to spin faster. It's pretty cool to see a designated Pill to do exactly this, would have liked to have seen it with a tiny filter over the end for those moments in vacuum.  The constant bleed pill has now been removed completely from the system and solenoid boost control has been restored once again.   Case closed 😂
    • The wideband reading is meaningless if it's not running. Why are you using shitty old sidefeeds on any engine, let alone a Neo? What manifold and fuel rail are you using to achieve that? Beyond that, can't help you with AEM stuff as I've never been their ECU/CAS combo.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
