No shit. Of course AWD is better, but I'd still take MR RWD over normal RWD. Personal preference of course though :)
And on another note... Am I slightly cooler now?
Edited by jezza boii
you must be blind... that's not flush. it's sunk in the back and poking in the front. and goddamn, get a wheel alignment and sus adjustment stat.
Okay, it's 2mm sunk. And 7mm poke at the front :) But it's much closer to flush than before.
Have booked in for a wheel alignment tomorrow morning. Will leave my car at work overnight.
jesus. you drove home like that? where'd you get the wheels n tyres fitted? they let you drive out like that?
I only drove back to my work, which is also in Dandenong.
The people that fitted the wheels aren't really tyre fitters. They just repair wheels. They helped me source tyres and did me a favor by fitting them for free.
Yeah, I hate the black strips. I'm getting them colour coded when the bodykit goes on :)
PS - Anyone know a good place to get my front guards flared? I don't want to get defected for my 7mm of poke.
bent suspension arms for superior traction when cornering left.
LOL :)
Guest
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
