Where can I get tow hooks in Melbourne?
http://www.revolutionracegear.com.au/index.php?PCID=10318&PSO=245&PSID=3100004500&PSV=Primary
i hate that troll faec thing most over done thing on the internet badddddddddddddd
your mum's the most over done thing on the internet.
i dont think it was neccessary to bring my mum into it, she's a very nice lady.
very dissapoint.
very dissapoint.
it's always necessary to bring your mum into it.
always.
Running a competition :) If my band's page hits 10,000 likes then I might be burning 2 Justin Bieber tickets on video :P (Giving people the choice to take the tix or have them burned)
Good advertising scheme? Or is this asking for trouble?
Or Moshen, you can keep the R32 till your off your P's and drive your Hilux around...
Are you positively annoyed friend? jelly!
Mo,
Don't listen to Jamie.
R33 FTW. I know I'm currently driving in a R32 but R33 shits all over R32.
:laugh:
This girl!
STFU.
Mo sell the 32 or I'll ban you till you get rid of it.
Ah yeah, cuz you don't wanna put up with his whining shit talk :rofl:
NO WAY!
the lux is falling apart, pretty much needs a resto, and 800 bux r33 owners way and i keep my head unit and sub
sounds like a good deal to me, and the scratches are gona get fixed too
STFU.
lol, should be a couple weeks.. fkn hate how my bills all come at the start of the month :sick:
Anyone interested in purchasing a Turbosmart e-boost street ebc? Retails around the $500 mark from memory. Will sell for $380.
f**kin sick boost controller at a great price.
will it fit on my non turbo horse?
Guest
    • So, before putting them in I need to understand the stock ride height. This is how I measured it: First, check the diameter of the wheel's centre cap, it was 52mm. Then put a piece of masking tape approximately across the centre and measure 27mm (half) from at least 3 sides to get a reasonable idea of the centre of the wheel cap. Mark that with a horizontal line as one measuring point. Then, directly above the wheel on the guard, put another piece of masking tape in approximately the centre. Use a string line to find out the point on the guard above the centre of the wheel cap and mark that. Then it is simple, just a tape measure to check the distance from centre of the wheel to the centre of the guard. Final results where  LF: 381mm RF: 379mm LR: 401mm RR: 400mm Pretty even considering they are 120,000klm old factory springs, lets call that 380 front and 400 rear.
    • So....knowing that I have a problem with power steering temps on track and another Wakefield day booked in next Friday, I've done the obvious thing They are very reasonably priced at $1650, considering they are a big monotube shock, double height adjustable (don't have to change pre-load to change ride height), one way adjustable damping and standard sized and customisable springs if you want something other than what comes with them. They come with 9kg/mm front and 4.5kg/mm front and I went with that as a starting point because I'll add adjustable sway bars too https://justjap.com/products/bc-racing-coilover-kit-ds-ds-infiniti-q50-v37-14-current#description Unfortunately they didn't come with rear strut tops so I've re-used the factory ones which was a bit of a pain. Also, the adjuster for the rear shock will be an absolute nightmare to get at, and while there are extensions in the kit I can't see any way you can actually attach or use them
    • I also had 2 bulbs blow at once, years ago in the stagea. made for a fun drive home. The issue was the voltage regulator had failed in the alternator and it was giving 15+ volts. Really, I was lucky all that was fried were the headlight bulbs. So, I'd suggest you check the voltage across your battery terminals with the car running and warmed up. Yes, you will need a multimeter to do so, sorry.
    • Good work to think to check that, and thanks for coming back to post up the outcome.
    • Given it happened suddenly, and when you come on boost, I'd check all your inlet - hose clamps in place and no split rubber or silicone hoses. Even the hard to get to ones near the intercooler. It's possible air that went past the air flow meter is being dumped out a big hole.
