  • Replies 122
I can get 10 sets sent to me, but I can't ship them to people for that. Feel free to post the link.
IF you guys are interested in a GB, I would need a minimum order of 10 and the cost of each will be $92 shipped to your door.
So with the exchange rate Im looking at $120.08 NZD delivered?
I should mention, to get these in properly you will need to make up one (or two or three depending on how pedantic you are) basic bracket to clip it down with, cut some of the underside of the shroud, a little off the plastic on your car and maybe even trim some of the engine bay.
If you take off your battery cover shroud, you will see the difference from one side to the other.
Edited by iamhe77
I don't know how much shipping will be to NZ yet.
I have one to send off (came in an order of other stuff), so will get a shipping quote then.
Please do. I need the full amount in NZDollars. Nissan NZ is charging me an arm a leg for the battery cover. FYI parts no is 65278-AM600. 64894-AM600 not including clips or brackets.
Does that mean someone is making the brackets? :D
Nope. I'd have to have actually make something on these to warrant making up brackets.
Price quoted is from US supplier and consists of battery cover, cover shroud, shipping to me and then shipping out.
Do what Scott said or go to Bunnings and grab some metal brackets to suit :)
Edited by iamhe77
I have used www.amayama.com before, they are cheap and reliable. Shipping is not too bad either. I did a search for the part numbers you listed and the resu;ts are below in Australian dollars.
cheers
benny
Search for part 64894AM600
Maker Original Number Name Price
upon availability
(AUDEURGBPJPYUSD) Delivery period
(days) Stock Nissan 64894AM600 $ 23.42 20 Add to cart UAE
Search for part 65278AM600
upon availability
(days) Stock Nissan 65278AM600 $ 5.21 20 Add to cart UAE
Edited by bennyb110
I tryed looking for the driverside cover but only ever found the passenger side. Must have been looking in wrong place
You need the passenger side one ie the one that comes standard on a G35. Remember that the US are left hand drive.
    • @666DAN sorry to bring you and old thread.     I've got my de+t done and it's all running great other than 1 small issue.    Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd when selected . But nothing when in  drive or what gear your in when you pop it into tiptronic. I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Do ya have any ideas?     Cheers man
    • Well I recently changed my rear axles and was thinking if I bumped anything, I have been driving the car for a while now though... But it has been raining today so everything is wet under the wheel arches. Brakes feel fine and can't hear any of the metal screamers, I had a squeak coming from one of the handbrake drums but that seems to have gone away a while ago. I was going down a hill when it lit up and I did feel the abs bite for a second and question why it did it?
    • Correct. Um. I dunno. I haven't cared enough about the way that the NA cars work to know for sure. But..... The 33/34 turbo manual cars have an electronic speed sensor in the gearbox that outputs a +/- (ie, sawtooth AC) voltage signal. That is connected to the speedo. The speedo then outputs a 0-5v square wave (ie, PWM) signal that the ECU (and any other CU on the bus) sees. The speed sensor is NOT directly connected to the ECU. So here's the problem. Your new ECU expects to see the PWM signal, but must somehow be getting a direct signal from the diff speed sensor. Which would suggest that the wiring of the NA car is not the same as the turbo cars. I think you will need to spend some time with (hopefully the wiring diagram for the car) and a multimeter to see what is connected to what. Then, presuming I am correct**, you would then want to separate the ECU speed signal input from the rest of the car's wiring, and probably either buy a speed signal converter, or build one using an arduino (or similar). That would take in the speed sensor signal and output a scaled (and suitably rearranged) signal for the ECU. ** We shouldn't presume that I am correct here, because there might be something else crazy going on. I don't think you could convert the speedo to be fed from the gearbox sensor, because the pulse rate from that sensor is probably different to the diff sensor and then the speedo would read wrongly. And this also wouldn't fix the ECU's problem either, because the ECU doesn't want to see the gearbox signal direct either (assuming that they are all on the same wiring, for some odd NA related reason, see above caveat!) Does this help? Probably not. Can you make it work? Almost certainly. With the above work. You should buy a handheld oscilloscope from Aliexpress so that you can view these signals directly. Connect up the probes and drive the car. Show photos of the screen when drving at known speeds and connected to different places, and we'll see what we can learn about it.
    • Assuming your brake pads are not worn right down, I'd add a little brake fluid. Is there any sign of a brake fluid leak?
    • Hello all,  I need of some help. On my drive home my handbrake light lit up and started flashing. When I got home I checked my handbrake sensor under the centre console and nothing seemed out of the ordinary. I have scanned my car via the consult port, no codes shown. Checked my brake fluid as well which is half full. Tried unplugging the brake master but it didn't change anything. Thoughts on what it could be? The master float doesn't seem to be stuck. My car is an 1998 ER34 sedan GT. No hicas but has ABS Photos below 👇🏾
