hey guys just looking at a few cams for the RB20... iv seen Tomei mostly and they are around the $1000 mark but CAMTECH CAMS make them for a bit cheaper.
Wondering what you guys think on putting a bigger cam on a lightly modifed motor?? Will i see many gains??? Im not to good on cams lol
Any help will be appreciated
Not on a mild rb20.
Power gains? Nope.
All you will do is shift the power band, and that is only going upwards most likely... so not doing a street RB20 any favours unfortunately :)
Pretty sure Troy tried some Tomei cams - He went back to factory cams if memory serves me correct
Check the RB20/260rwkw thread, it should have the details in there either way in far more detail :huh:
unless you want to push 300hp+ i would be upgrading other area's of external bolt on's and having spent a fortune on a RB20 i would
advise anyone, the money is better spent on a 25 conversion or 25/26/30 combo. The money it cost me to get over 400rwhp
could of got me over 500rwhp in a RB25 and a more usable power band, but in saying that i still like the little 20.
Cams on std engines with little turbos with small A/R hotsides dont seem to like cams. Now a built RB20 with a big 0.86 A/R 500hp turbo....cams may help....nobody can reliably tell me which is making me nervous about building up an RB20, nobody can give you a tried and proven recipe :blush:
Cams on std engines with little turbos with small A/R hotsides dont seem to like cams. Now a built RB20 with a big 0.86 A/R 500hp turbo....cams may help....nobody can reliably tell me which is making me nervous about building up an RB20, nobody can give you a tried and proven recipe :bunny:
roy i got 321hp = 240 rwkw outta rb20 with 264 in / ex cams and hks 2530 0.63 at 19 /20 psi
would you not agree most rb20 with just straight 2530 + 20 psi = 230 rwkw? if so then approx 10 rwkw gain ?? ( I know very very simple comparison and every dyno is diff etc)
Not saying this is what id do on a mild engine as bang for ur buck is not really there
same cams i think make big diff with the rb22 on 2835 use more of the rev range where the rb20's love to be
Things is i made 260rwkws with std cams, installed 260/8.8mm cams and lost response and 10rwkws, even with tweaking the cam gears and tune for about 75 dyno pulls. Could not get it back, too much bak pressure from the tiny 8cm housing i run
260-280rwkw 1.2-1.4bar standard rb20 here. The 280 was with a boost leak too :bunny:
same turbo as Roy's but different plenum.
I'm thinking about giving Status' cams a go when I have the time. But I wouldn't think you need cams till about this power level.
Correct me if im wrong but any mild or more serious cams on an rb20 is only going to shift the curve and fatten it up while it is there. But it wont do a whole lot for low down.
didnt you make that power with 2530 on ALLSTAR hubber, its known to read 5-7% higher which would be around 20hp... Which would mean around 300rwhp on roller which is pretty much dead on normal
Edited by Cerbera
yeop yeop ... cool was just trying to give some comparison coz no one seems to run cams in their 20's
as said im in agreeance, doing it again i wouldnt bother, spend the extra $$ on other performance mods
Yeh i know two people in Melb with 2530s and Poncams and they dont feel that different to an RB20 with a 2530. Sound better but thats about it :banana:
I cant remember the settings other then retard the hell out of the exchaust cam (from memory about 4 deg)
What about Poncams with cam gears? Is it possible to get, to a degree, stock like response with the benefits of aftermarket cams?
What benefit? The two 2503 powered RB20s with Poncams drive like a RB20 with std cams. There isnt a tangible improvement in my eyes. Could be wrong though. They both make power where you expect, they both make about 220odd rwkws. They both have boost drop off at high revs. I think it comes down to the fact that eveb though the engine is happy enough to breath with std or aftermarket cams, with the lil 2530 and other 320-350hp turbos they simply have too mcuh back pressure in the exhaust housings and choke the engine up.
I had a friend with an R33 with Greddy plenum, HKS cams and a 2530. It made 230rwkws and came on like there was no tomorrow. but i dont think the cams did anything for it either until he got the 3040, T66 and other setups on it
yeah im fairly sure it's just +2 inlet -4 exhaust, just need someone to confirm
to be honest even with a gt2530 cam gears are a waste, the inlet does near nothing and the exhaust frees up a bit with a bit of retard but again minimal. The rear housing is the restrictrion not the head (cams etc)
refer Roys post it is bang on
Thats why i am going back to the 10cm housing, Plazmaman plenum...will see if cams work for it then. Need to beat that R31 fella making more power then me :)
Come on Trent, give me the specs of something you have seen work. :) I am torn between installing my solid lifters with some 260/10.25mm cams to go with the 10cm housing and 2.4L bottom end or just keep my money in my pocket and keep reving the crap out of the lil std motor and see how it goes. I am so hot and cold about all this :( Its safer to go with a known RB26 or RB30 setup, but.... :)
As if im going to use a pissy little 2530 :)
I've got a ATR28G3 with 0.63 rear... Same turbo as you tuned for Stao a while ago and made 500nm of torque, so my question still stands :)
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
    • Funny, but really not funny. Thank god (most) f the world has moved on since then
    • Lots of votes for driving onto a plank first; that is the quickest way I've found, 25mm is enough for my case but that will vary by car It also depends where you are going for. On the 32 I can get to the rear diff with my floor jack if I do that end first, and get it up on stands. Then I lift the front from either front tow hook as high as needed, also onto stands. Sometimes I need a small lift on the other tow hook to get it level enough If I do the front first I can't get to the rear diff because of the angle of the car Other options are getting to the front mount of the rear subframe from in front of the wheel (if only lifting one side, or just do both which is a bit of a pain compared to one lift from the diff), or also the gearbox cross member mount on the driver's side if you are  just trying to lift the driver's side. I This is the jack I use; it says 75mm clearance but of course that is only on the lower section so if you have to reach too far in like the diff you still get stuck. https://www.snapon-bluepoint.com.sg/category/Floor-Jacks/product/Floor-Jack,-2-Ton-Low-Profile
