I'm becoming very frustrated with my current engine...
Basic rundown - its an RB30DET being an R33 S2 turbo head (completely stock).
The bottom end is built, with CP pistons, eagle rods etc. and a final CR of 8.9:1
It runs a GT35R internal gated exhaust housing, but running external. (.82)
It has all the supporting mods necessary, and runs an EMS stinger.
2.5" intake piping, 80mm TB, 3" dump and straight exhaust.
I run a built RE401A, KEAS full manual box, all upgraded internals, and a 4200RPM stall from MV.
This bucket of shit will not make any power. It's killing me. I have had it on a few dyno's to see what each person thinks, and no one can give me an answer. Yesterday, on a 'hub' dyno, it made an incredible 352rwhp @ 17psi. 16 degrees of timing all up. AFR's around 11.8 and peak power @ 7100rpm engine speed.
What the F#ck can I do? It's hard to say if it is lacking power because I am yet to take it down the strip. At one point, it managed to make 340rwhp @ 11psi but I think this was a relatively lean tune with heaps of timing.
I'm going insane. I am starting to think that maybe the auto isnt working with the combo. I know power figures are not everything, but this sort of power doesnt make any sense out of an GT35R fed RB30/25. I dont know what I am asking from you guys. I guess some suggestions/advice about anything really. I am lost.
https://www.sau.com.au/forums/topic/313296-twin-cam-30-is-driving-me-mental/
Stock head with VVT?
Does the EMS operate VVT correctly?
I'd be expecting you could run a lot more timing than 16 degrees too - again making me think of your cam timing.
One thing we do have to fix is the VVT. Electronically, its not working. Hopefully it's an issue with the wiring rather than the ECU. The EMS is supposed to be able to run it.
Cam gears dialed in correctly?
If I had to stab in the dark, I would maybe say something timing related. I was out one tooth on intake before a run once, totally different power outcome.
Just a suggestion, everything else looks OK mod wise. I woulnd't think the auto would pose any issues.
do you have a dyno run you can put up?
Pretty sure the timing belt is set-up right. All marks match up correctly and the engine has been running for about 5000kms. Well, the white dot on the passnger side cam gear is slightly off-line from the mark on the back cover, but definitely not one tooth out...
I can probably get a dyno sheet up at some point if you think it would be worth it? Will have to ask the guy that tuned it to send one through to me first.
Yeah... it is missing a stupid amount of power. Yeah the auto sucks a bit, but I thought it would still make around 400rwhp on a normal dyno.
Running stock exhaust manifold I'd think you'll pull around 430ish hp on that boost when things are right.
If the VVT isn't working, that's the main source of problems. Don't look any further until it does work.
Then you should be looking to be able to run more ignition timing.
Both of those things will stop you making a bucketload of power.
Edited by Dale FZ1
OK. Will make efforts to suss that out then.
Running a 6-Boost too so plenty of flow there :cool:
I didn't realise it was that low? What should it be around?
Also... does anyone know if the exhaust housing of the turbo, being an internally gated turbo (with port now just blocked off as I am running external) would be a significant restriction, and whether it would be worthwhile replacing the housing for a proper external gate one?
I dont want to spend $700 on a housing for little gain.
Edited by cactus
VCT wont make any difference to top end, unless its powered up all the time.
I would run it up with the std converter, but only after scoping the timing on the balancer and comparing it to the figures the EMS is "thinking" it is using. What ems is it? some are pretty crude in regards to map resolution under boost (no scaling adjustment).
Hey status, a question to clarify my understanding, not to question yours at all....
VCT changes the duration so that the intake valve opens/closes later when enabled right?? and is only enabled in the top end.
wouldnt this result in big loss's in power up high.
I think thats one of the things i had shown to me recently but i might be confused.
s15 doing 200kw with vct enabled, dropped to 150 without (might have been as high as 170 my memory is foggy).
which bit am i getting wrong??
NVCS is OFF from 0 - 1050rpm, then ON until 4700rpm, then OFF again until redline.
Therefore the NVCS advances cam from 1050 until 4700rpm then it switches off allowing "normal" cam timing.
If the vct was wired up to be engaged all the time it would be advanced from 0rpm to redline... this would affect power, hence my first post.
If left disconnected top end power will not be effected only power to 4700rpm
It's an EMS Stinger... the baby one.
The timing on the computer is the same as what it is up front. Initially, this wasnt the case. It was 20 degrees at the computer and 25 degrees up front. But they adjusted this yesterday. Damn, I was getting my hopes up thinking the VCT could make a big difference to the output.
Are there any issues associated with running it from 0 - 7000RPM?
Edited by cactus
yeah if anything on all the time is far more detrimental to off all the time.
    • The car/ECU will have all the sensor that it needs and expect to have. I think i do not have to explain to you how the Link is way better specialy if you have swapped engine   I just do not want to deal with any "problems" cuz i have only Nistune which i learned is not that great and in my case cant even deal with that speed problem (Link can) And of course it will be way more easier to tune and diagnose and safe. And for the ECU/speed problem...i dont know.
    • Per Mark Roberts of Sonictune: Mark Robert Author At this time, no. No ETA either 2016-17 models. You will be able to purchase and install a 2018.5+ TCU though   TCU purchasing and pricing info! As we near the release of TCU tuning, I am going to answer some questions I get asked often.   What do I need for TCU tuning? At this time, you will need a 2018.5+ TCU to be able to tune. If you have a 2016-to early 2018, you will need to replace your TCU with the newer version. One good way to know if your TCU is good is if you have auto upshift in manual mode in 1st gear around 6500 rpms. If your manual 1st gear goes to 7k rpm and will hit the rev limiter unless you shift, you have the older TCU.   Why do I need to buy another ecu license/phone flash if I already have it on my ECU tune? The TCU is its own computer module. It is completely separate from the ECU. Because of this, you will be required to purchase a TCU license and, if your tuner has it, the phone flash license required to tune it via phone/bluetooth.   Do I need TCU tuning? TCU tuning is NOT required. However, the faster your setup, the more it will assist in track and dragy time consistency.   If I’m ECU tuned by (tuner A) can I get my TCU tuned by (Tuner ? Yes, since it’s a different module and a completely separate flash, you can have two different tuners. However, it is highly recommend that you have both tuned by the same tuner. For me, my TCU tuning will directly complement my ECU tuning style and features and running my ECU and another TCU or vice versa MIGHT cause some issues. At this time and for the foreseeable future, I will only be tuning my current ECU tuned customers TCUs.     I have a SYVECS AWD controller. Do I still need it? Yes! The AWD controllers main job is to control your AWD system. However, with TCU tuning, you will no longer need the auto-shift function as that will be done through the TCU. The AWD controller will still be very beneficial for racers looking to maximize traction on the launch.     Shift schedule changes: holding gears longer at lower pedal input as well as max shift rpm changes. Please note, the new ECU race rom coming out will address 90% of the shitty drivability issues these cars have through custom maps from myself and Racebox—as well as others I am sure.   Increase shift speeds: as seen in the videos I’ve been posting, the TCU shifts much faster once tuned.   Increased shift pressures: as also seen in the videos, much firmer full throttle shifts.
    • The fancy pants red shock tower brace is finally incoming from MX5 Mania, getting it shipped from 'Merica has been a long and problematic process, and GWR, the 'Merican supplier will not ship directly to consumers outside of the US, Mania basically had to order a heap of them, the colour choice was silver, or red, and we all know anything red adds 5 killerwasps of dynotorques..... Whilst it does fit over a 2.5, and I've seen a few photos and videos of it being installed and fitting, google also says it might get real close to the FAB9 intake front runner, people in the US says it does fit with the FAB9 intake, except for one person who said it slightly touched.......so there is that.....LOL..... As it seems that I am the first in AU to have this combination of parts there's no local knowledge about fitment, so I'm just a willing guinea pig in this endeavour, I'll cross my fingers and toes and hope for the best In other news, I ordered stuff from China  on the same day I ordered the 23° silicone bend from Victoria, the stuff from China arrived a day ago, the 23° silicone bend is still travelling around Australia thanks to Australia Post, and "may" be here next week
    • Very good news...I contacted Racebox about it last night. My car is a 2016 so remains to be seen if it is compatible, requires a TCU swap, or is impossible.
