or the F40.... IN THE 80's!
But that was cool, cause the outer 2 were from the turbo's, and the middle one was from the wastegate.
Don't think that PM35 has a wastegate :rolleyes:
Except that the 458 isn't turbo... stupid nostalgia trip!
its strange that most car companies are now producing a retro model of some description. Some work out OK I reckon, but some are just dogs.
If Ferrari wanted to put 3 exhausts on the 458, they should have put turbos and a wastegate on it!:whistling:
I wonder if when F1 goes back to Turbo's in 2013, companies hero cars will then become turbo again- like the 80's?
Funny how Ferrari get away with it when they put them on a 458 Italia...
Difference is;
1. Ferrari 458 is beautiful (and I'm a Lamborghini guy!)... although I don't really like the rear lights
2. The exhaust is in the middle of the 458
3. It has a specially designed rear bumper designed to "work with" the 3 tipped exhaust
4. Not styled similarly to a Volvo :P
Difference is;
LOL
Difference is;
Now that triple zorst tip looks HOT...
Too bad they catch on fire easily though...:teehee:
Edited by ironpaw
on the topic of tires. which im not very good at calculating as I have No f**kin idea on how the calculations work.
if on the stock 18" ARX wheels i have 245/50R18's which is the standard rolling diameter for the ARX, and I wanted to go to 19" x 8.5 - pretty much same as Bbenny's wheel, what tire size would I need??
I want to stretch the tires a little to.
i tried searching a calculater, but i dont even know where to start!
I like this one: http://www.miata.net/garage/tirecalc.html
or this one:
http://www.rimsntires.com/specs.jsp
Damn the standard ARX tyre size is 245/50?
If you going 19's in 8.5 I reckon 245/35 or 40
If your gonna stretch it a little go 225....lol
My uncles givin me a free set of the below..
235/35-19
same brand i got for scott I cant remember.. lol is that ok?
nup you should be 245/45-19
oh...and stock spec's
http://exchange.goo-net.com/catalog/NISSAN__STAGEA/10018465/
Edited by Jetwreck
http://exchange.goo-...TAGEA/10018465/
well thats probably why mine always looks like baloons lol
Bluestreaks?
If they're good enuff for Scott...then they should be ok...maybe...
looks like 234 45 or 245 45 as craig said.. the ARX has different rolling diameters to yours.
    • Hi everyone, I've been wrestling with this for a while now and have been trying to find out the cause. For context, the turbos used are Garrett 2860 -5s, the BOV is a BNR32 HKS SSQV IV kit, the car is currently tuned to ~470 whp on 17.5 psi. The car drives normally, pulls well when it doesn't happen, and I can replicate it fairly easily. It does not sound like turbo shuffle or flutter. The engine has only a thousand or so miles and has had this behavior since it was completed. After my engine was built for my R32 GTR, I noticed that the car now sometimes makes an air discharge sound on what appears to be positive boost pressure that sounds really similar to a BOV. I had thought that it was a BOV issue but even when replacing it with a brand new unit, the sound persisted. It seems like it's coming from the passenger side but I may be mistaken. The closest scenario I could find was this post here https://www.gtr.co.uk/threads/maybe-a-boost-leak-opinions.147955/https://www.gtr.co.uk/threads/maybe-a-boost-leak-opinions.147955/ started by @yakshii and it sounds very similar. As in, at partial throttle once I reach positive boost I begin to hear the same psh psh psh psh psh sound like air is leaking somewhere when I keep the throttle in the same position. It most commonly happens in 4th gear at around 3-3.5k RPM and 5th gear around 2.5-3k RPM, which seems to coincide with normal positive boost thresholds. It might be similar to what @Austrian GTR mentioned about his own HKS SSQV. Notable difference would be that when he applies more throttle when it happens, it stops. In my scenario if I apply more throttle during this repeated psh psh psh sound, the cadence of the sound gets faster and louder rather than stopping. If I lift off slightly and apply throttle again, it will normally stop and pull without issue. I've checked all rubber couplers to ensure that they are tight, but have not gotten the opportunity to properly do a pressurized boost leak test. If anyone has had similar experiences or thoughts on what might be the cause, I'd be very keen to hear them. I also have a video of it happening from inside the cabin, if that would make it easier to understand: https://youtu.be/2zqZXcx8jbA
    • I'd want at least $40K for mine, but thats easy to say cos I'm not selling anyway.
    • That's incorrect. We have 4 seasons, consisting of pre winter, winter, post winter and a small glimpse of hope!
    • I spotted a black C34 in Mittagong this morning!
