Will watch you make 650 at the treads with a turbo for under a grand.
Haha I got the BB version so it was a bit dearer than that! Might make that power output with a VE head and massive cams but my aim is to keep / if not better the response and make more up top too. Keep you posted on the next cruise coming up too Dave :(
I've had first hand experience with a few Precision turbo setups now.
A 2.6 33GTR with a 7175 making 860bhp... very smooth and progressive in the lower end. It was alot more responsive than the simiar non-billet wheel PT turbo. Absolute animal on boost... I love it!
Another 2.6 33GTR with a 6265 making 700bhp and a stonking 192mph standing mile run... that was his first/only run too. The car is suprisingly "responsive" for the size turbo.
An RB25 with a 5557 in a S13... a little smoother than a td06, with similar power potential. It was limmited by the injectors at about 280rwkw, but lots of torque.
And of course, I watched first hand(didn't get to ride in) the Performance Power TT GT40 at a standing mile event... amazing!!! it has twin 75mm prototype Precision Turbo, billet turbo's.... It's obviously a larger engine, but when Johnny puts his foot on it from idle, the thing comes alive very very quickly!!!
I've actually bought a 5557 plain bearing, billet wheel T3 for my daily rb25 r32... I really want to do a comparison with a td06 l2 (that why I bought plain bearing core).
Justin.
justin,
any news on your 5557?
just a suggestion.
why not make a group buy for this turbo?
i sure want one of those 6262 journal bearing with a SP cover
If people are interested, I can organise the purchase of PT turbo's if you wish from my Florida supplier (I'm in florida at the moment). And make shure they get shipped correctly etc.
My supplier is a fellow enthusiast (it's a large marine diesel workshop) and only sells this stuff on the side... Awsome guys!
He also tests PT combo's on his awsome 33 GTR.
Just PM me.
Cheers
Justin
Please have a part number if you PM me...
I'm not a PT dealer or workshop/professional... So please don't ask me for advice.. Contact PT direct for product info. And I urge you to do your own reaserch.
I can comment on they're build quality and for a coupe of set ups using PT turbo's.
Just so you know, PT have a 38mm and 46mm ex wastegate too.
Cheers
J.
Here's the link to one of the first PT set up's on a buddies r33 gtr... the details listed about the motor are incorrect.
http://forum.aempower.com/forum/index.php/topic,24641.0.html
It has:
No Port work.
Tomei cams not HKS.
Greddy intake manifold, not stock.
Stock gearbox and twin plate.
It's a fairly basic engine build. Rods- pistons and a good oil pump.
It's also sitting on a china- no name ebay manifold- ha ha ha!
There was also a small problem with the coil packs breaking down above 30psi and a CAS timing problem.
The car has also run a 6865 and currently had 72mm on it.... rebroad minded persons soon. The new 72mm seems to spool a little quicker than the 70mm. With out a re-tune, the 72 runs alot leaner off boost and under full boost... alot smoother too. We're expecting to see 900 to the tire.
Hope that helps
Justin
  • 2 months later...
I would not mind seeing a small precision like a 6262 or 6265 on an RB25/RB26... they make awesome power on EVO's in the states at high boost. Would be good to see!
I'd like to see a pair of ceramic bb, billet 5557's with the smaller V band exhaust housing, on a 26.... they have an awsome surge ported 4in intake comp cover option too.
I'll post up as soon as I get results on my rb25/5557 combo.
Cheers
Justin
  • 1 month later...
Well mine is on and should be tuned in a couple of weeks!
Word in the pits is Powertune in Sydney have become agents for Precision and will be testing the well known sizes on their SR20 first and a big one for their R34.
Time to put an end to these Mustang and DynoJet figures!
Big issue is no Australian dealers, means you gotta pay a fair bit for shipping and there's a long wait if anything goes wrong. If someone local would start supplying them I'm sure they would be a great alternative.
Would one of these be a good option for an RB20 potentially soon to be upgraded to an R34 RB25de+t? In the 180-200rwkw range.
A standard rb25 turbo would be fine for that.
Edited by Rolls
    • Biggest thing is you're okay!   It sounds like between the accident, and the drive home, it was a pretty torturous trip again! On the bright side, you took the opportunity to enjoy the event more from the perspective of a spectator, than as an entrant!   Sad to see so much damage to the car. It really has taken a HUGE hit in the front end. If/when you choose to repair, hopefully the rails are straight (At least from shock tower backwards). Hopefully the extra cage coming through there has save most of the chassis rails, and HOPEFULLY saved the motor too. Best of luck when you eventually get motivated to start pulling it down to check it all out
    • Sounds more like what Brad said, that it's mainly transfer. What pad bed in procedure did you use, and did you replace/machine the rotors, or just swap pads?
    • The stutter is almost entirely in the pedal. I don't feel the brakes release and reapply as you would with ABS engaging but the pedal feels that way, without the brakes releasing. It only lasts for less than a second and the pedal is fine again. It's hard to explain, sorry.  I'll get under this weekend and just double check everything is tight. Fluid is at max where I left it.
    • What bedding in procedure did you use?   When you say stutter, what exactly do you mean? Like it feels like someone letting go of the brakes momentarily and regrabbing them again to get you to stop? Re-reading your post, and that is what it kind of makes me think you're explaining, like theres a little bit of a jolt, likely just as you're reaching a stop. I've only had this issue once. And if its caused by what caused mine, you will want to get the car up on stands again and check it over. Mine was a case of a caliper mounting bolt coming out and letting the caliper rotate on the other remaining bolt and gave play in a wheel as it came to a stop. But not every stop either!
    • Yeop... binned it   This will be a summary will not many pics atm and cbf  Fixed the samsonas - it was totally munched Put a new precision 7675 T4 on with proper split pulse mani Got to Sydney to get to car - drove to canberra to get racecar - drive back to sydney that night Next day all day at Plasmaman putting on new clamps cleaning some things up and adding another large engine oil cooler sitting at the rear above diffuser to keep things cooler Next day - Tuesday - on Dyno - killer wikid awesome pumped out really good numbers - more mid range and on lower boost levels Wednesday - first prac - all day again getting the suspension right - had to borrow front suspension again - out do a lap come in - out do a lap - in - what i had just couldnt handle the load at the more consistent higher speeds - got a lap in at the end of the day that was pretty reasonable  Put it this way that lap wouldve had me in 4th in Pro am for the whole event - with only 700 hp and used tyres Thurs first official prac day - lap out warm up - then entered a hotlap with above setting and 80% effort took corners 1,2,3 and into 4 car felt awesome -  rear came around out of nowhere bang into the wall near front on at whatever 140 kmph Done, over, gone Just one of those how did that happen apparently as all indications show nothing out of the ordinary Got to spend the rest of the time at the event like I hadnt done before - was actually Ok mainly as I had my family and my boy is 9 and got treated like a rockstar Long trip home, lost a trailer wheel in nowhere land, X5 airbag suspension gave up half way across nullabour and rode on bumps stops (its now completely fine) had to do a 19 hr drive day on day 3 as accommodation got screwed up so just had to keep driving till found a town with some Now to reassess - hopefully the motor and other things are OK but yet to be seen too. There is no easy fix there is no i'll just order that part and get it sent - we'll have a talk to people see what can happen and what the go is but at minimum its rebuild from scratch struts forward and alot of time effort and $ should and if I return and if but maybe/ when  I have the cage tied into the front strut towers - if I didnt have that things couldnt been worse you can say its just a front end but if you know what goes into these cars... you'll know what that actually means in reality   Car was very fast. Disappointing we just didnt get to show it Effort doesnt win you races though     Apparently this is motorsport !
