:worship:
Would you like to share your opinion here.. My setup:
OEM S15 DE 10:1cr
VCT delete S13 DE cams
Water injection (not planning to use meth and still on 98)
All relevant supporting mods
Thoughts if I strapped a 5557? Do they come in a twin scroll? I would be willing to run it in the early 20psi range.
I am only considering setups that big now because of the WI kit, otherwise I struggled to avoid knock on a 28RS and the wrong cams :domokun:
Dammit...If I hadnt just lost my job an hour ago I would have ordered one of those 6466's on Monday :(
Jerks Terrrrk mai Jerrrrb
Why does it seem like you indefinitely just lost your job?
Move to Sydney, FARK.
OEM S15 DE 10:1cr
I am definitely a lot more sold on the new Precision CEA turbos than I was the older Precision units, very impressive results - though for what you describe there I still favour the likes of a ForcedPerformance HTA GT3076R, if not HTA GT3073R for an SR. Those things have an awesome reputation for response versus their normal Garrett (etc) counterparts, and just happen to punch above their weight too... the Precisions in that size range from all I've seen also punch above their weight, but tend to be a bit laggier too.
How did I know I would get an FP HTA response out of you ;)
But your right and I will need to consider those too!
Not for me thanks, not spending a dollar on the stock twins
Can anyone point me in the direction please for some of these turbo results on a JZA80 but not using over 30psi? eg "normal" boost levels?
Would be nice to compare to a GT3566-82R
I have see mid 400kw with one of those an an RB30 at 25psi.
I have always heard the 3566 should be a gun...but I have only ever seen them on rubbish setups and not making the power they should
I'd assume it would come on somewhere between a True 35R and a t04Z, which on a 2J won't be that bad, are you staying auto steve?
    • Did you panel beat the dents or have you tried to repair this only using filler?  Is your sanding block soft/flexible and is following the shape of the panel rather then just knocking down the high points?
    • I haven't knocked them down yet. I think I made the repair more complex than it should have been. I had rock chips combined with waviness and dents and I tackled it all in one because it was near each other and just end up wasting a bunch of bog lol. I'll knock down those areas and see how I go. And yep what you are saying at the end is correct. I think I might be sanding the top of a steep hill then my sanding block falls into the dent and gets rid of the guidecoat if that makes sense. Though shouldnt unless I'm covering too big of an area with not a long enough block. I'll try something new and provide some updates. Getting there though! Thanks as always.
    • Yeah makes sense, hard to comment on your situation without seeing what your doing. I was talking generally before, I would not be looking to randomly create low spots with a hammer to then have to fill them.  It's hard without seeing what your doing, it sounds like you are using the guide coat to identify low spots, as you're saying the panel is still wavy. I don't see how you're not ending up with patches of guide coat remaining in a wavy panel? Once the high spots are knocked down to the correct level, surely to have a wavy panel you need low spots. And those low spots would have guide coat still in them?
    • So I'll put filler past the repair area a bit to make sure I don't miss anything. Then I'll block it until it's almost level, put the guidecoat, then keep blocking until it's gone. Then it's still wavy.  In regards to hitting the panel, I saw this video might give more context - Skip to 0:47 he knocks it down. But yeah I'm sanding until the guidecoat is gone then checking because otherwise my filler is still well above the bodyline. Unless what you're saying is I should put guidecoat around it early, surrounding the filler then stip once it's gone?
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
