  • 3 weeks later...
Where is the flex join Jez? Exhaust looks good other than that.
I have never used a flex join on my exhausts scotty. The dump pipes are very secure near the gearbox. Plus it will test out the 6boost manifolds strength :)
Mitcho im hoping for 400kw from mine and 350+ from the R34 with 5558.
The main thing im aiming for is response. Well as much as possible with a 400kw turbo. I will be tuning mine with stock cams for now. Then poncams, then when the headgasket pops i will look at variable intake cam and port work. I will be testing the bottom end on my 26. If it lets go i will worry about it then.
Brilliant attitude!
Hope it all goes well, they're both going to be flex fuel aren't they or is it just yours?
Edited by Mitcho_7
I always run a flex in the screamer pipe as the expansion between off gate and on causes the pipes to move too much. The gate pipes are cold then become white hot as the gate opens. (get a video of it on the dyno, its impressive.) It will most probably crack at the base where it joins the dump and load up the gates and manifold/studs like you said. Bugger removing it all for repairs to save the $20 a two inch flex costs.
Thanks Scotty i will look into them tomorrow. Is easily added onmy car but on the 34 the wastagate pipes is only 2 inches long and turns 90 degrees in the 2inches.
Have u seen any crack due to the reason stated?
Besides mine will be on gate more not haha. Dyno time then trailer to circuit.
Here's hoping you can crack a 10 mate, it will be a nice setup.
I have seen one crack a stainless manifold within an hour on the dyno. (that was with a venting screamer.) I also watched my exhaust grow longer by over 2 inches and glow red at the tip. I can just imagine the stresses on the tubing up the hot end.
That sounds pretty wild, bet Jez is glad you mentioned this prior to him getting them on the dyno
It isn't really an issue if you like pulling the parts back off to weld them but I bet its a job and a half to fit. I just did a split 6boob install and it was a pita, especially the gate position. I fabbed it all in the car though.
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
