The 6266 would match the current power on some decent boost. But if u want to out power the T51r u may need to use a 7 series PT.
What are u going to use the car for? How laggy is it now?
Was planning to use it at the drags here in Tassie but looks like our track is closed down.
Its making 24 psi @ 5200 but my exhaust system was restricting it.
Which box is it exactly? I'd be more inclined to go a 6466 or 6766, if it's a power sucking C4 :) They are rated at 900/935hp.
I have the power sucking C4 :rolleyes:
if the 6262 goes 500 it must be the best turbo in the world, response of factory turbos and power of a large laggy heap of crap.....
I'd like to go up to Jez's dyno when my engine is done. Put it on there for 2 or 3 power runs then overlay it. From whats been shown so far, it could be big single time ;)
FOR SCIIIEENNCEEEEEE!!!!!!!!!!
Sorry, couldnt hold it back. Now do it.
I am sure a 6262 could do that power on a DD, and that would not make it the best turbo in the world imho as there are others in similar territory. Here is an old example of what these turbos can do...
I woudn't look to AWD motorsport stuff to see what that would do(or any precision)..lol, unless you want to run no gate and
let the sucker make what it makes..lol, he did that on supraforums to a customers supra aswell,, 7675, making 7680 numbers.....and he did it to the record setting lancer in the video above , the thing apparently nuked itself not long after
I like his attitude and his balls though, haha
cheers
darren
Edited by jet_r31
cheers
darren
Of course that is kill mode, but that's serious business for a 62mm turbo without nitrous oxide
76mm compressor, garrett Gt42 S trim turbine(aka 4202), so sameish size as what you have( or same size as GTX4202), but if you have no
track i'd go smaller, be a toss up between a 6766 and a 7175 i reckon..
cheers
darren
Edited by jet_r31
PJ, what have you seen the 6262 and/or 6266 go to power wise?
Will the 6266 crack 500?
A 6266 will crack 500rwKw all day on an efficient engine. A mate of mines car made 491kW on a plain jane GT35 with .82 T3 housing, then went out and ran a trap speed of 147mph, 1400kg car including driver!!!
Yeah that sounds more like it Lithium, 900whp is a MASSIVE number given the size of the compressor and turbine wheels
My 6766 peaked at 853hp on Mainline at 42psi, running it any harder may have just caused drama's so we called it a day.
The yanks have gone very fast with these turbo's no doubt, they also have the cars setup to take an absolute pounding. I believe they have gone as quick as they have without any GST on the story, I still find it amazing how they are going 145+mph on FP Red's though.
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
    • the Tomei LSD fluid with lsd kit. frustrated that it was shaking the car to crap and affecting everything else negatively, I pulled the diff last night, and removed the lsd carrier, could not find anything wrong, however it seem to be 100 locked up acceleration, and deacceleration, wondering if they sent me a 2 way not a 1.5??  either way I installed the stock open carrier back in place. test drove everything smooth as butter again. no shake, shutter, random, what felt like clutch slip and grab or drive shaft play, etc. something differently wrong in side the lsd. I might bother taking it apart (if possible) to figure out what's going on inside this carrier, as bought too long ago to return.  only draw back is its back to a one wheel wonder.
