Interesting comparison. It appears the -5s may have its measure when you factor in they ramp a tad sooner and with E85 may be able to get the ignition wound in sooner ? Real curious to know if they drive as per the textbooks with the twins offering a little more transient response ...any torque graphs?
lol its not definite yet, but I have the invoice for a 55
58 .64
was going to pay it this week but funding fell short :( will need to wait a few more weeks maybe
I cant find any results with this turbo. It looks about the right size for my YB Cosworth (cruiser/street car) but still thinking an FP71HTA.
Do the internal gate setups work well...all the results i am googling are external setups. The R34 GTT seemed to be external for its 350rwkws so perhaps a 5130 is all i need for a grunty 280-300rwkws...happy to run up to 26psi
Do the internal gate setups work well...all the results i am googling are external setups. The R34 GTT seemed to be external for its 350rwkws?
Yes it was external 44mm plumbed in.
Will be tuning sr20 with 5558 external this week or next. Just running motor in
thats more or less what I'm chasing but isn't the 5180 an old t3t4 based dinosaur?
yavuz at unigroup seems to have talked me out of the 5558 and back onto a simple 20g. Just as well I ran out of money before I hit the invoice
Really? Why did 5 if his customers just buy 5 precision turbo's but he tell u not too? Weird
I have been building though, Roy. A very basic setup but I wont be affraid to throw 25psi at it if I have to. Forged slugs, stock rods, race bearings, studs, springs, retainers, cams. Most of the work is done just need to get my crank crack tested and the springs put in the head.
It was Mick who did the asking for me on his recent trip there. Mick let him know about the type of setup im building and projected output and drivability, the verdict was that the 5558 isnt going to delivery the type of performance I want. I am envisioning it will be more like a 3076R, which I drove an SR w3076R on the weekend and it sucked HARD.
Ive sent off to see if I can get a PT 5130 for similar money to the 5558........ If I can then I think its a winner. PT market it as a replacement for an actual 3071R, meant to out perform in every way. See what the price is before I get too amped.
Powertune sell the 5130 for something like $1300. Its basically what I think I have decided is the go for my 2L 4cylinder...just need to do some more homework regarding internal vs external wastegate and flange connections and stack it up against the 71HTA with Cossie rear housing
WHOA hang on, Ive just realised something rather important. PT is advertising that item is a 56.5mm turbine.. Now normally they advertise the exducer size but I am thinking this is the turbine inducer. AKA a cropped GT30 turbine ala HKS 2835 spec.
A normal GT30 turbine has an inducer of 60mm and an exducer of 54.98.
However, the HKS spec 2835R has a 56.5mm inducer turbine.. The cropped one.
To back this up the internal gate housing is just a run of the mill GT28 spec thing.
AFAIK that is BAD news for us pissy 2L boys. Thoughts there Roy?
20Gs make power at 19psi...Precision turbos seem to like over 24psi so if you don't have s built engine?!?!
All the ones i have done have made big power on 22psi. Havent needed to go bigger boost as of yet
I am aware of 1 result on an ethanol powered RB25, what arent you telling us Jezzabelle? :P
Pretty sure u know about my GTR's results too :)
Another rb25 i finished made 301kw 16psi with a 5557 last week. On 98. With a microtech thats wandering majorly at high rpm. Stoopid ecu's
i no man, ill work it out one day, got a new exhuast coming and a new intake setup. So ill try that out, and c how it goes. If nothing improves ill just drive it as it is, till Stevo comes up with the goods on the bits and peaces to make her a lil bigger on the bottom end if you no what i mean, than prob throw the -5s in the bin lol
im very interested to c how this turns out but
Lets put it this way; you'll be having a new bottom end quite soon. The engine for testing is waiting on one part before assembly, and that part is being picked up at the end of this week and sent...
Kinoath lol. I wish! Should be an interesting comparo between mine and pauls. Pauls has a mega dollar head and nismo collector, ive gone the budget route with a quick port job at home and the standard collector. Cant wait!
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
