I have with the HKS cast manifold which has the wastegate sitting right on top. The very short run to the gate is the worst it can be if you want to keep both sides divorced. I am guessing there wouldn't be much in it once gasses start moving at any speed.
Is that stainless ?? can't wait to get my stainless mani in favour of mild steel.... might be alright if it doesn't get too hot.
had heaps of issues with turbo to mani gaskets etc, and Grant at Per4manz turbos is pointing the finger at the stainless and turbo rear having different expansion rates...stainless is something like 10mm per 1m.
you might not be putting as much heat as the TO4 at near on 2bar, so might not have any issues...just saying (-:
I think so, but looks identical to that one. no cracks or anything, just trouble mantaining a good seal between turbo and mani, Grant thinks due to stainless flange against cast mild?? , had them both faced a couple of times, tried every type of gasket. The permeflex ( or whatever its call ) 5 layer one thats on know seems to be holding up, but hasn't seen too many long track sessions yet.. next time it lets go, its a 6-boob steam pipe or similar.
Pffft PJ. Joels is slowly catching up. U too should race :) rules are no higher than 6000rpm hahaha
Just got his off the dyno, full boost 24psi @ 4300rpm revving to 7500 335kw
Will push for more boost soon. Had to take it for a run
E-Flex, that's E85 yeah?
Top end power is great but a little laggy? I'm reading 15psi@4250rpm, 20psi@4500 and 24psi at 5100rpm (all approx). Do you think these can be improved upon with better boost control? What size gate is on there now?
I've got a 5858 and was hoping for better response that that but not so sure now!!
Don't forget it's a 2L SR20 not a RB25
It's making at around 4300rpm which I wouldn't have thought is too bad at all
Yes understand its a SR20 which is what I have.
The top end is sensational and a great result. Don't get me wrong, not meaning to be critical but would have hoped for more action a bit earlier.
In any case a dyno doesn't tell you how a car feels on the road.
Like I said I have a 5858 that is going onto a 2L (maybe a 2.2L) so am really interested in the response and power of these things. The slightly larger turbo should be able to make 350rwk or so. I guess I will find out later on.
I dont think the lag is as bad as it looks. You cant expect too much response from a 2L with a 300+kw turbo man.. For me its really on par and I think its a good result.
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around without a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
