I have with the HKS cast manifold which has the wastegate sitting right on top. The very short run to the gate is the worst it can be if you want to keep both sides divorced. I am guessing there wouldn't be much in it once gasses start moving at any speed.
Is that stainless ?? can't wait to get my stainless mani in favour of mild steel.... might be alright if it doesn't get too hot.
had heaps of issues with turbo to mani gaskets etc, and Grant at Per4manz turbos is pointing the finger at the stainless and turbo rear having different expansion rates...stainless is something like 10mm per 1m.
you might not be putting as much heat as the TO4 at near on 2bar, so might not have any issues...just saying (-:
I think so, but looks identical to that one. no cracks or anything, just trouble mantaining a good seal between turbo and mani, Grant thinks due to stainless flange against cast mild?? , had them both faced a couple of times, tried every type of gasket. The permeflex ( or whatever its call ) 5 layer one thats on know seems to be holding up, but hasn't seen too many long track sessions yet.. next time it lets go, its a 6-boob steam pipe or similar.
Pffft PJ. Joels is slowly catching up. U too should race :) rules are no higher than 6000rpm hahaha
Just got his off the dyno, full boost 24psi @ 4300rpm revving to 7500 335kw
Will push for more boost soon. Had to take it for a run
E-Flex, that's E85 yeah?
Top end power is great but a little laggy? I'm reading 15psi@4250rpm, 20psi@4500 and 24psi at 5100rpm (all approx). Do you think these can be improved upon with better boost control? What size gate is on there now?
I've got a 5858 and was hoping for better response that that but not so sure now!!
Don't forget it's a 2L SR20 not a RB25
It's making at around 4300rpm which I wouldn't have thought is too bad at all
Yes understand its a SR20 which is what I have.
The top end is sensational and a great result. Don't get me wrong, not meaning to be critical but would have hoped for more action a bit earlier.
In any case a dyno doesn't tell you how a car feels on the road.
Like I said I have a 5858 that is going onto a 2L (maybe a 2.2L) so am really interested in the response and power of these things. The slightly larger turbo should be able to make 350rwk or so. I guess I will find out later on.
I dont think the lag is as bad as it looks. You cant expect too much response from a 2L with a 300+kw turbo man.. For me its really on par and I think its a good result.
    • Jack the back of the car up, pull that wheel off, pull that sensor out, and put a bore scope into the hole to inspect the outer casing, see if anything looks damaged before you pull the whole thing apart.
    • Ergh... So I pulled the speed sensor out again and the tip was shiny so I think it's rubbing the bearing. The bearing contains the magnets for the speed sensor so I think when the first sensor broke it damaged the magnet ring on the bearing.  This is just a Google image, but there is a hole going to the bearing. So when the tip broke off the old sensor I'm guessing it fouled the bearing... As the magnet is only protected by a plastic cover it would be easy to damage it. So I guess I'm doing a bearing again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
