LOL Simon, that car is fast. Sky is also blue, but I just wanted to say it.
How do you get your freaking helmet to fit? Im only 180cm and a helmet like yours in my S14 does nothing but trade colour schemes with my hood lining.
Is the Bride mounted super low or your shorter than me or what? It shits me to tears, I need to lay my seat back heaps and slide around like a moron at the track lol
haha
Response wise the 6262 really impressed me over the weekend. Did lots of roll ons from 60km/hr (just under 4000rpm in 2nd gear) and every time it was cracking gate almost instantly on 100% throttle application.
Check out this run with an XR6 Turbo that runs a 11.9 at 120mph at the drags. I hit the throttle at the big bollards and it is straight on gate (24psi)
Is it me or are these Precision turbo's very quiet on song? Every video I have seen they are quiet as!
Bulldog run Simon. Congrats :D
The mid frames hardly make any noise, when you're cruising they make a multi-pitched noise though, you can notice it at night.
The larger frames like my 7175 "almost" sounds like a T51R.
What power was the r32 it making in this video?
It was making 600hp on a hub dyno, we tried to tune it on a roller with about 4psi more boost but it just wheelspun at 560rwhp,
Best guess would be 650hp at the wheels
Edited by SimonR32
Here's an update for the RB26 VN at the track. Still a bit off its potential on this power (910hp at the wheels on 25 psi), but it's getting there! Weighs 3315lb with driver, has steel, glass and a heavy interior.
I'm sure you'll enjoy the sound.
Would weigh 3314lb after losing that side skirt at the start.
Amazing machine
Here is an insane result for an RB26, I can't get my head around the spool and power this thing has made - a mild built (no porting, not extreme cams) RB26 with nearly 500kw @ hubs/665hp @ hubs with excellent spool on a PT6266 BB:
Thread:
http://www.gtr.co.uk/forum/166866-nats-r32-gtr-3.html#post1762728
Raises some eyebrows to say the least.
Things to consider, it's on SAE correction on old software so I would say it's around 600rwhp on a roller (but that's on normal fuel not E85)
You have to wonder how long the ramp rate is, 350hp at 4000rpm is about double what I would be expecting from that turbo
Edited by SimonR32
They are certainly capable of pushing beyond their power rating, but I've seen some figures floating around with way too much GST on them.
If they aren't done on an engine dyno or backed up on a track, they are just that...numbers.
No doubt, mine isn't getting pushed at all and it's starting to get right up there power vs power rating wise.
I just find it hard to imagine a larger turbo on basically the same motor set up as mine and Jez's is making almost double the power at 4000rpm and a huge extra wack of hp top end all while using 99 Octane fuel not E85
If I thought that graph was genuine and repeatable I would have already sent an email requesting an invoice for the purchase :)
Edited by SimonR32
    • An update regarding the registration with the DVLA I sent off the paperwork the day after I collected the car from the port, two weeks later it was all returned with a letter explaining they have rejected the application. This was because the cheque was £20 short for the road tax (I used a price list I found online). Nevermind it is what it is, it was sent back to them the following day with a new cheque. Fast forward another 2 weeks or so, I called them for an update to be told it had been rejected. Yesterday (16th September) I received the documents back along with another letter, this time it was because I didn't put an X in one box on the V750 (personalised number plate certificate), which declared that I had the rights to the personalised number plate. Why this wasn't mentioned in the first rejection letter, I don't know, but it could have saved this headache. The documents were sent back today, so fingers crossed third times a charm and it'll FINALLY be registered on the road just in time for the bad weather (woohoo!) To cheer myself up I lowered the front 25mm, was sick of seeing it sit like a monster truck. No idea how much clearance I'll have getting on and off the driveway, I'll worry about that when I can actually drive it
    • You're going to miss not worrying about rust in the strut towers like the Skyline shitboxes out there
    • A few little updates that weren't filmed due to not taking long to do or not interesting enough for their own video. My new K&N Air Filter arrived, I went with an RU-4180 which matched the dimensions of the universal cone filter the car originally had.  The battery had gone flat, while that was charging I tidied up the spaghetti wiring at the bulk head and down the sides of the engine Next job was to swap the stereo The Kenwood harness had the female ISO plugs cut off and the male ISO plugs cut off the adaptor loom and joined with bullet connectors. I ordered in a repair loom through work and re-did it all. New Kenwood unit installed (Android Auto, DAB, Bluetooth, Reverse Camera) The bonnet/hood gas struts have been poor since collecting the car. I couldn't find any suitable replacements locally so took a chance on a pair from AliExpress.  The originals don't use a retaining clip to secure the cup onto the ball fixture, would explain why I struggled for 10-15mins trying to pry off the cups. The ball fixtures unscrew using a 12mm spanner, new ones are the same size. Sadly no photo of them fitted, you're not missing much lol The dished Momo steering wheel got replaced with my Momo Tuner, turns out I ordered counter sunk bolts for the horn trim ring (like they normally are for the steering wheel) instead of allen cap (flat seat)  A terrible photo of a Quaife style gear shift knob I've had stashed in my tool box for many years after purchasing the incorrect thread size (I can see a pattern emerging with ordering incorrect parts...) Also threw in a cup holder and a (empty) Boss Coffee can, because why not
    • GT-R clearly the better choice! The 300 is certainly not insaly fast but has a decent amount of poke. Does a nice little drift around the corners with a decent amount of throttle. It's VERY predictable in a slide too.  Feels so progressive! People probably presume there's a 25 year old driving it based on my behaviour this week! 🤣
    • Yeah Jap import. Fairlady Z then! I'm a bit the same.  They've been on my radar for a fair while but then just impulsively decided to buy one!  Was going to just buy an NA and add turbos to it later but decided to save the f'ing around and just buy the turbo version.
