LOL Simon, that car is fast. Sky is also blue, but I just wanted to say it.
How do you get your freaking helmet to fit? Im only 180cm and a helmet like yours in my S14 does nothing but trade colour schemes with my hood lining.
Is the Bride mounted super low or your shorter than me or what? It shits me to tears, I need to lay my seat back heaps and slide around like a moron at the track lol
haha
Response wise the 6262 really impressed me over the weekend. Did lots of roll ons from 60km/hr (just under 4000rpm in 2nd gear) and every time it was cracking gate almost instantly on 100% throttle application.
Check out this run with an XR6 Turbo that runs a 11.9 at 120mph at the drags. I hit the throttle at the big bollards and it is straight on gate (24psi)
Is it me or are these Precision turbo's very quiet on song? Every video I have seen they are quiet as!
Bulldog run Simon. Congrats :D
The mid frames hardly make any noise, when you're cruising they make a multi-pitched noise though, you can notice it at night.
The larger frames like my 7175 "almost" sounds like a T51R.
What power was the r32 it making in this video?
It was making 600hp on a hub dyno, we tried to tune it on a roller with about 4psi more boost but it just wheelspun at 560rwhp,
Best guess would be 650hp at the wheels
Edited by SimonR32
Here's an update for the RB26 VN at the track. Still a bit off its potential on this power (910hp at the wheels on 25 psi), but it's getting there! Weighs 3315lb with driver, has steel, glass and a heavy interior.
I'm sure you'll enjoy the sound.
Would weigh 3314lb after losing that side skirt at the start.
Amazing machine
Here is an insane result for an RB26, I can't get my head around the spool and power this thing has made - a mild built (no porting, not extreme cams) RB26 with nearly 500kw @ hubs/665hp @ hubs with excellent spool on a PT6266 BB:
Thread:
http://www.gtr.co.uk/forum/166866-nats-r32-gtr-3.html#post1762728
Raises some eyebrows to say the least.
Things to consider, it's on SAE correction on old software so I would say it's around 600rwhp on a roller (but that's on normal fuel not E85)
You have to wonder how long the ramp rate is, 350hp at 4000rpm is about double what I would be expecting from that turbo
Edited by SimonR32
They are certainly capable of pushing beyond their power rating, but I've seen some figures floating around with way too much GST on them.
If they aren't done on an engine dyno or backed up on a track, they are just that...numbers.
No doubt, mine isn't getting pushed at all and it's starting to get right up there power vs power rating wise.
I just find it hard to imagine a larger turbo on basically the same motor set up as mine and Jez's is making almost double the power at 4000rpm and a huge extra wack of hp top end all while using 99 Octane fuel not E85
If I thought that graph was genuine and repeatable I would have already sent an email requesting an invoice for the purchase :)
Edited by SimonR32
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
    • Is this a brand new LSD? if so, have you followed any break/bed in procedure for it? Usually involves heaps of figure 8 patterns, a fluid flush.
    • It's TWO steering wheels actually. 😛 one for each hand They are wheels, and they steer!
