Such a nice looking engine, please tell me your going to clean up the throttle bodies and the throttle body plate some more :( I know i should keep my negative comments to myself but it would look so much nicer if they were bead blasted and looked like new!!!!
Also could i suggest upgrading the oil pump to a Tomei pump. An N1 probably wont last too long on an engine with that sort of power.
Will a 6262 make that much power at 25ish psi of boost? 600rwhp is 450ish rwkw.... i am running a 6766 and make 485rwkw at 25psi with a pretty damn healthy RB26
I just chucked some 264 9.7 cams and upgraded valve springs In
Waiting for 2000 injectors then it's going for a retune on the 25th jan see what we can get out of the 6266 now as it was running out of fuel last tune
yeah, itbs, and runners are in the shop as we speak to get cleaned up. car will be in the drag occasionally, mainly street use and not a lot of abuse. was told that N1 with a got collar should last but def will consider getting a better pump
I've got a lot of evidence to show otherwise?
How early man? It's a lot of turbo to have breathing that heavy, that early, on a 2.6.
I can't picture your result here and now but I know its impressive. Remind me when it's making that sort of boost (1 bar).
I'm just blind estimating. I come from a sr20det swap with a gtx3071 and I didn't see 15 psi till past 5.5k rpms. If SimonR32 can show some proof of the spooling I'd be happy with the 6262. Now if the 6266 is behind just a few hundred rpms i will consider it as well.What rear housing? Would like to see the difference of 15 psi vs rpms between the 6262, 6266 on a 2.6 with similar cams. Thanks for the help guys. There is not many people with rb26 in my area so ita hard to get advise
This is a log I uploaded a while ago, I wasn't actually testing just driving but as you can see it makes 1 bar in 3rd gear at about dead on 4000rpm
Jose, if you were seeing boost that late for a 3071 on an SR then there was something either faulty with your car of you had a bad wrong combination.
I have never seen a twin scroll 6262 on any RB26 not have 15psi by 4000rpm on ethanol. I'm sure you'll be happy with one on a SR, just keep in mind the 6262 is capable of power beyond what is safe on 98 octane (for an SR20.)
thanks for the advise guys,after looking at SimonR32 chart im sure ill be reall happy with it. Ordered the precision 6262 ball bearing T4 .84 divided housing. do you guys use a restrictor for the oil feed? I will update after tune. I'm not sure if I had a bad combination on the sr but I just got frustrated with it and that's why im going RB26 this time.
That wouldn't surprise me too much but the T78 is a smaller turbo so not comparable. Compare a T88 with the T51R and the T51R response will look a lot better, then no doubt go to a modern 67mm billet turbo and things start getting quite interesting <br /><br />Sent from my GT-I9505 using Tapatalk<br /><br />
The fitting in the turbo has a restrictor built into it so you shouldn't need to fit one. Someone please correct me if I'm wrong though
Just out of curiosity what is the correct thread for the oil feed fitting? I found 1/8 npt didn't seem to wind in as far as I'd like
    • Thanks for the quick reply. To be clear, when you say turbo shuffle do you mean turbo flutter "stustustu" or referring to something else? I had thought they were the same thing. When I wrote the post my intention was to say it wasn't a flutter/compression surge sound. My understanding was that a flutter sound would be occurring when throttle is released, whereas I can keep the throttle in the same position for this noise
    • Hi everyone, I've been wrestling with this for a while now and have been trying to find out the cause. For context, the turbos used are Garrett 2860 -5s, the BOV is a BNR32 HKS SSQV IV kit, the car is currently tuned to ~470 whp on 17.5 psi. The car drives normally, pulls well when it doesn't happen, and I can replicate it fairly easily. It does not sound like turbo shuffle or flutter. The engine has only a thousand or so miles and has had this behavior since it was completed. After my engine was built for my R32 GTR, I noticed that the car now sometimes makes an air discharge sound on what appears to be positive boost pressure that sounds really similar to a BOV. I had thought that it was a BOV issue but even when replacing it with a brand new unit, the sound persisted. It seems like it's coming from the passenger side but I may be mistaken. The closest scenario I could find was this post here https://www.gtr.co.uk/threads/maybe-a-boost-leak-opinions.147955/https://www.gtr.co.uk/threads/maybe-a-boost-leak-opinions.147955/ started by @yakshii and it sounds very similar. As in, at partial throttle once I reach positive boost I begin to hear the same psh psh psh psh psh sound like air is leaking somewhere when I keep the throttle in the same position. It most commonly happens in 4th gear at around 3-3.5k RPM and 5th gear around 2.5-3k RPM, which seems to coincide with normal positive boost thresholds. It might be similar to what @Austrian GTR mentioned about his own HKS SSQV. Notable difference would be that when he applies more throttle when it happens, it stops. In my scenario if I apply more throttle during this repeated psh psh psh sound, the cadence of the sound gets faster and louder rather than stopping. If I lift off slightly and apply throttle again, it will normally stop and pull without issue. I've checked all rubber couplers to ensure that they are tight, but have not gotten the opportunity to properly do a pressurized boost leak test. If anyone has had similar experiences or thoughts on what might be the cause, I'd be very keen to hear them. I also have a video of it happening from inside the cabin, if that would make it easier to understand: https://youtu.be/2zqZXcx8jbA
    • I'd want at least $40K for mine, but thats easy to say cos I'm not selling anyway.
