they arent bolt ons lol Definitely not the ones Joe showed me thats for sure.
Those were my twins. . .I split the setup (twins/manifolds) and sold it. . .
Precision doesn't offer the rb26 specific turbine housings, you can purchase the 4828's without their hotside (-$100), but will have to buy the 707160-5 housings and throw them on the 4828's. . .as far as piping goes my plan was to fab up some hard pipes all the way. . .
Guys this tread is wary too long, maybe this needs to be closed and a new one opened as i know theres new precision turbos out so makes the start of the tread useless.
Anyways i currently have a td06 25g that puts out 320kw on 18psi full boost is around 4300rpm. I want a precision turbo equivalent but with more response as i feel the td06 is a bit laggy. Also on e85 i hope to get at least 360rwkw :DD so which precision would suit me ? I'm confused with all these numbers..
ALSO i want to low mount it for stealth
HKS 7071 :)
The two sizes relate to the "visible" size of each wheel, ie compressor inducer and turbine exducer. Puts things into perspective when you consider a PT6466 flows more than a T51R Kai, and even a FP Super94 HTA (aka, FP6768) is a fair bit smaller wheel wise while being capable of T51R SPL flow
  • Like 1
HKS 7071 :)
Are you using compressor maps to compare flows and pressure ratios? .... :P
Haha I was wondering if I would be called on that :-P I'll eat my hat if someone can show an unmodified T51R Kai making more power than the highest power 6466 setups, but yeah I was perhaps making a tall call on the Super94 haha... In all fairness the T51R SPL probably has an outright edge, just there is a fair chance of 90pc of people who use them won't see ever make good use of it.
Sent from my GT-I9505 using Tapatalk
Highest ive seen with a T51R KAI on an RB26 was 603awkw at 30-32psi.
That's the one with the upgraded compressor that ran at JEM? But yeah, folks have gone over 600kw in Oz with 6466s - bigger numbers in the US but obviously dyno comparisons get a bit iffy :)
Aggroman - there are others that make that sound too :D But yeah, safe bet with a T51R.... it's one of the things that disappoints me with the Precisions, they all sound pretty run of the mill. Yeah, I let the sound influence my turbo (and other parts) choices :teehee:
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
