6466 + stroker = loves it. Ignition breaking down over 29 pounds so this was the limit. I think it will do for now. :)
What's redline on this?
Looks like it will want to break things. Lots.
I want one.
Well had the exhaust done, did not pick up much power but it helped where I wanted it, response.
since I changed the Turbo,Cams and Exhaust the car has gone from a pig to drive to being fun, enough up top and good bottom response,street drive :)
Here is the latest Dyno
New Dyno 345.4 KW
Red = Boost off
Blue = Low Boost
Orange = High Boost
Old T78 = 337.9KW
That is a significant different there in where peak torque is made, good job.
Poor old T78 :) Did you end up getting my PM?
Epic result Mitch must be an animal?
That on a 3.4L?
Is it in an R?
She's a beast on the road, i love it more and more each time I drive it.. Yep 3.4L kit in my R34 GTT.
I want one.
Upped the limiter to 8000 now. Peak power is at around 7400. The whole driveline has been upgraded so here's to hoping it doesn't break anything!
  • 1 month later...
Hi Micheal
Sold the T78 and the bloke is happy, crap it was just about new, well 5 years ago and only 3000Klms on the car since it was installed
No I did not get your PM as it would come in on this Laptop, it does not allow me to gain access to anything other than threads and posts, but better than nothing. If you would like get me as TT350GT I can access everything on my PC.
I have caught the Mod bug and going to have the RB30/Nitto 3.2 Stroker kit shoved into it, keeping the PT6262 may get a bigger back housing and go for response, it is a DD and I want it to be what I thought it was when I bought it.
I have to say that since the last modifications I got to love it but need more and might have to come out of retirement to pay for it,bloody cars ,haha
I have caught the Mod bug and going to have the RB30/Nitto 3.2 Stroker kit shoved into it, keeping the PT6262 may get a bigger back housing and go for response, it is a DD and I want it to be what I thought it was when I bought it. I have to say that since the last modifications I got to love it but need more and might have to come out of retirement to pay for it,bloody cars ,haha
Haha, that's great :D can't wait to see how it turns out!
  • 2 months later...
does anyone know if precision will release a gen 2 6766 or a tubo slightly bigger than a 67 but still retain twin scroll, as anything larger than a 67 seems to be only able to be bought with a single entry rear housing.
7175? Or FP Super94 :P
  • 2 months later...
OK so the Precision PT6870 CEA is out now - from the initial testing it is serious serious serious business, ultra impressive.
See here: http://www.supraforums.com/forum/showthread.php?859938-PTE-6870-CEA-GEN2-Test-Results-by-Sound-Performance
PT7275 versus PT6870 (all testing on the same engine setup):
7275div981010whpvs6870811059whp_zps5ba3a
PT6766 versus PT6870
676681949whpvs6870811059whp_zpsb7426611.
Spool comparison:
Those dyno results are all "max effort" on a good motor and high ethanol percentages, so likely to do them all justice. The spool and the relative power versus the 6766 and 7275 impress the hell out of me, nuts.
Yep, quite interesting. All results were impressive, though that particularly made me think of the GTX3067R result someone on here got.
Not sure if referring to my GTX3067 result, or typo, but nonetheless also found the results of 0.81 v 0.96 very interesting.
Below quote from the original page in particular:
The .96 A/R only added lag and if you reference the boost spool comparison below, we also weren't able to see as much boost with the duty cycle all-in. This tells us that we were at a limitation of the compressor wheel flow itself and not because of back pressure.
Not always beneficial to go larger A/R it seems.
Anyways, sorry to digress from subject of thread. Thanks Lithium for posting above info.
Keen to max out a 6870! Hopefully they release divided housings for them sometime soon. Certainly looks good on paper, gotta love those GST yankee figures as always :)
6766 rated to 935hp, makes 949hp atw.
Yeah those numbers seemed high for a 6766 on a Mustang, though I am still shocked that people are taking hp ratings as some kind of gospel. How much did you make atw on your old GT3076R? And what are GT3076Rs rated at?
The 6870 is certainly looking the goods, no matter how you slice it. Would have loved to have seen FPs Super94/99s on more things - they are in T4 twin scroll and imho until this came along the best thing since sliced bread for the ">6766 power without going BIG frame".
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
