Finally had the tune...
So stoked for the little rb25 with 647 hp @ wheels on 28psi.
It actually comes on the converter 200rpm sooner than the to4z.
I need cooler plugs and a bigger wastegate and it should make 700hp pretty easy as the 647 was with early shut off cos of break down and boost creep. image_11.jpg
  • Like 2
I am about to go down the 6262 (0.63 rear) path on my rb25. I'm chasing 280kw ish low boost and 320 - 350kw high boost. Engine is built and has supporting mods. Just unsure as to what gate pressure I should run for low boost. Fuel will be 98. Was thinking between 16-18psi low and 20-22psi high.
Small rear housing plus 98 isn't a very good idea imo.. I made 288kw on a GTX 3071 on 98. Id look at something smaller than a 6262 for 280kw.
That kinda power can be had on a stock lowmount position kinda turbo.
Big $$$ changing manifolds and plumbing up EWG etc for a laggy 280kw - 350kw IMO.
Edited by Mick_o
I drove a supra locally here that makes 350kw @ 16psi on a gt3582 with a 0.63 housing on 98. Looking to make 320kw+ in the high boost region, so it must be able to get there if the 3L can do it without it choking. If I have to run a little more boost to get there I will. Just trying to work out what spring I should be running in the gate for low boost to roughly get in the 280kw area.
5858 0.84
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
    • the Tomei LSD fluid with lsd kit. frustrated that it was shaking the car to crap and affecting everything else negatively, I pulled the diff last night, and removed the lsd carrier, could not find anything wrong, however it seem to be 100 locked up acceleration, and deacceleration, wondering if they sent me a 2 way not a 1.5??  either way I installed the stock open carrier back in place. test drove everything smooth as butter again. no shake, shutter, random, what felt like clutch slip and grab or drive shaft play, etc. something differently wrong in side the lsd. I might bother taking it apart (if possible) to figure out what's going on inside this carrier, as bought too long ago to return.  only draw back is its back to a one wheel wonder.
