  • Replies 351
Posted Images
Just an update so you guys know whats going on. I'm just waiting on a response from the supplier for the full address of the account holder and the full address of the bank the money is going into. Apparantely Australia has pretty tight security for international money transfers and just the bank account details are not enough. Hopefully they reply today so I can put the money through.
Sorry for the slight delay guys.
Lol its going to be another 30 kits in the next bloody group buy looks like it.
As an update guys, they have received our money transfer and the kits will be sent out to me some time next week once all the kits have been made up. I have purchased all the express post envelopes so as soon as they are sent to me i'll send them out.
Cheers
If they don't fit I bags them!! :(
Will be happy to pay what you paid for em + postage if you are down with that.
Sure mate :(
Thanks Basho!
Look forward to receiving them PM-R33 :(
hey pm r33, i know your gonna be busy with finishing this group buy off and personal life.... but you got a rough idea when your gonna be able to start another group buy and maybe try to get the braided clutch kits as well as braided brake lines to?
As long as the supplier doesn't have a problem with it I can do another one straight after this one ends; once every one in this group buy receives their kits and is happy with them.
So at a guess the next group buy could be in about 2-3 weeks possibly. The main thing I want to ensure is everything goes smoothly, there aren't any problems and people are happy with the kits. So as long as all that falls into place, i'll do another one straight away for the clutch lines and brake lines.
Edited by PM-R33
No news yet, but it is only the start of the week. I'll give them an email tomorrow to see how it's all coming along and where we are at.
WOW, you handled this awesome Phil!!! Count me in for next buy for a clutch line!!!
i've dealt with Phil before this guys and he's nothing short of perfect to deal with.
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
