  • Replies 351
Posted Images
89CAL Posted Yesterday, 06:49 PM
are the people involved in this group buy going to get first preference for clutch line group buy?
+2 to that :)
x 3 :(
x 3 :)
x4
Hopefully about a week if all goes well. Once it gets to me it shall be Express posted to everyone so that should only be a day or two.
Cant wait. Need those lines so i can do my brakes. mine are rooted at the moment, have to use the handbrake cause the metal on metal noise is killing me. I got the new rotors and pads just need the lines.
Shit, sorry to keep you waiting man. I will write out all the Express post satchels early next week, that way the day they get here I will start sending them out so they get to every one ASAP.
Just to add to the ADR/DOT approval discussion. The guys told me that they included some paperwork for the kits which is certification to prove they are legal just to make 100% sure we don't have any dramas :P
Yes I will be able to get them for a WRX, however you will have to wait for the next group buy if you don't mind waiting. As soon as this group buy is over (within the next week or so) I will open up the next group buy.
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
