  • Replies 351
Posted Images
Latest list:
1. PMR33 - R33 GTST
2. LUKAS 33 - R33 GTST
3. DYSONEST - S13
4. LOKIR33 - R33 GTST
5. TOYGTR - R32 GTR
6. 89CAL - R33 GTST
7. MR TURBO - R33 GTST
8. DORI34 - R33 GTST
9. BASTI - R33 GTST
10. EVLGTR - R32 GTR
11. ZEPHYRO90 - R32 GTST (PNG)
12. PEZHEAD - R33 GTR
13. ROBBO RB180 - R32 GTR
14. FORCEFED - (awaiting confirmation of kit)
15. MLR - R33 GTST
16. RYAN WILLIAMS - S13
17. XRATED - R32 GTR
18. XRATED - R32 GTST
19. …………
20. …………
Can you do them for an R34 GTT ? if you can please put me down for a set. :D --transparent. and please pm me details for payment
Edited by BASHO
Wow! Ok people I think that will do, there is obviously a lot of interest in this and I think we should get the ball rolling and see how this turns out. If everything goes perfectly I will do another group buy for those people that missed out.
So if no one has any objections with this, this is how I would like to work it:
I will PM everyone with my bank account details in the next 24 hours (5 minute wait time between PM's is annoying) and confirming the kit that you wish to order. If everything is correct, please deposit the $105 into my account ASAP. Please also reply to my PM with your full name and mailing address. I will wait one week until next Friday 9th April for everyone to make payment and then I will order the kits. If payment isn't made by that Friday than sorry you miss out, I think one week is more than enough.
If you missed out on this group buy but really want to get in on it, PM me and I may still be able to add you to the list depending if people drop out or whatever. If there is any problems or questions, once again feel free to send me a PM.
FINAL LIST
1. PMR33 - R33 GTST
3. DYSONEST - S13
5. TOYGTR - R32 GTR
6. 89CAL - R33 GTST
9. BASTI - R33 GTST
15. MLR - R33 GTST
19. MR MOO - R33 GTR
20. BASHO - R34 GTT
21. MARK/1979 - R33 GTST
22. MR SCARY - R32 GTST
23. SXY 33 - R33 GTST
24. BRANDON - R33 GTR
25. TYPEVU - R32 GTR
ADMIN - please leave this thread open until I give confirmation that all kits have been received, thank you :cool:
Thanks everyone
Edited by PM-R33
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
