I am near completing fitting out the front facing plenum. The fmic is in and piped up, that was quite easy, as was most things after, as Darrin put it, a few drinks.
Now the original procedure was via stuff from Skylines, and the fuse boxes in the 33s is different to the Stagea, Thats a bugger caus you cant turn the T/B 180 degrees not even without a spacer. So I got all the bits in except the BOV. This was shown as being on the cold side of the IC. This means a massive piece of 30mm tube to get back to the inlet if you are not atmospheric BOVing.
Then thanks to KiwiRS4T(Bob) who is researching the same subject, I saw a BOV, vented back to the OEM inlet pipe, on the HOT side of the front mount. Now is this wise? I need some feedback as I am worried that the unloaded gasses may be too hot.
Help!
https://www.sau.com.au/forums/topic/314318-bov-relocation/
Help!
I was always under the impression that the closer the BOV is to the throttle body on the cold side the more efficient it works, as it would release pressure from the point furthest away from the turbo...
its not uncommon to have a piece of pipe running from one side of the engine bay to the other as a return, as coming from s15's that's how they were stock...
my 2 cents tho...
https://www.sau.com.au/forums/topic/314318-bov-relocation/#findComment-5157843
I run a front facing plenum with BOV in the hot side plumbed back to intake. Works fine, shouldnt really matter. Heres a photo to hopefully help you out, I know its not a stagea but may still be helpful
PM me if you want more photos
https://www.sau.com.au/forums/topic/314318-bov-relocation/#findComment-5157876
Im interested to see if you guys notice a loss of response with going the forward facing plenum, im contemplating doing it on my R34, but i dont want to lose any response or mid range, and being they have shorter inlet i would assume you would lose some?
https://www.sau.com.au/forums/topic/314318-bov-relocation/#findComment-5158232
I guess Duncan would be the best to talk to. Or go to Skylines and look up Front Facing Plenums. There is a fair bit of info there. A lot of 33 drivers have done it.
Also if the runners were longer it would be better low down, but there is not much room. I think it will be better up top.
Edited by 66yostagea
https://www.sau.com.au/forums/topic/314318-bov-relocation/#findComment-5158403
I presume you mean off boost but I don't expect it to make any difference. On boost I thought the point was to reduce the length of piping and so reduce lag?!
https://www.sau.com.au/forums/topic/314318-bov-relocation/#findComment-5158551
my particular plenum has quite long runners for greddy style....but I can't make any comment about response because I did the 3l block at the same time....
considered running no bov like me? it makes a very childish noise which makes me giggle :P
https://www.sau.com.au/forums/topic/314318-bov-relocation/#findComment-5159982
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
