hi
ive got my bloody hicas light coming on after about 10 or so mins of driving on my R32 GTR
it has an aftermarket steering wheel, and the diagnosic test said this is the problem..
my question is how do i get to the steering angle sensor ? i know its behind the steering wheel but what does it look like?
anybody have photos or a step by step guide on how get to it?
also when i do get to it, what needs to be done to it, what do i clean? align ? etc
sorry about all the questions but its driving my crazy !!
thanks
https://www.sau.com.au/forums/topic/314341-steering-angle-sensor/
was it doing it before the aftermarket wheel? if your aftermarket steerng wheel is causing the problem, check that you have got a proper hicas boss kit.
i dont know if there's any maintenance you can do on the angle sensor. i guess check for dry solder joints on the circuit board, and maybe blow it out wih compressed air for good measure?
this is what mine looks like. from a S1 r33 with no airbag.
it sits behind the steering column shroud. easy to take out once you have the wheel and shroud off. just 4 screws and a plug
thanks mate !
i bought it with a nardi steering wheel, so i didnt touch it....i dont think it has a boss kit? arnt boss kits so you can remove ur steering wheel? the steering wheel is not removable its bolted on
i will sus it out anywayz, make sure everything is cleaned up
can you align the discs on the angle sensor? are they markings on the discs that i should take note of?
no you cant align it. the stock steering wheel, or an appropriate boss kit, will have holes in the back of it to accommodate the arms sticking out of the angle sensor. when you turn your wheel, the sensor turns with it.
thats how i understand it anyway.
also, yes you do have a boss kit. your nardi wheel is bolted to it with 6 bolts around the horn button. the boss kit is what attaches your wheel to your steering column.
  • 4 weeks later...
just read on previous posts that the hicas light will go on if the brake fluid is low on R32's ? i just realised mine is disconnected ?! where does it go, cant seem to find the place to plug it into !! so the connector is just hanging there ?
i think the brake fluid container has recently been changed, maybe for compliance?
what to do hmmmm
  • 6 years later...
thought i would revive an old thread. cant seem to find what i need to find searching.
im fitting a nardi wheel with a saas bosskit which has the holes to properly house the two plastic parts for the steering sensor.
the bosskit has 2 sets of universal holes for different wheels to adapt, for my wheel to align it is on a 30deg (ish) angle to the locators. this is easy to fix as i just turn the locator to suit keeping the wheel aligned with the spline.
will this cause issues with the steering sensor and hicas? does this need to be inline with the spline or does this just start locating electronically on start up in relation to where it started from?
  • 3 years later...
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
