Too true...add to that shuddering/surging on throttle lift offs...will give him a week before he has the factory BOV reconnected....
Hecctik...
Awesome pic, though strangely only appears when I went to reply, not normal.. Weird :S
Anyway, my prelude has a great dose, not a crappy VL type one, but a grunty manly one <_> No problem with shuddering or surging, and its got a brass button clutch too, and its fwd, and tyres bald, and its 220KW :)
hey guys.. have just notised two lines im not sure about... 1 is coming from the p/s compressor- which go to the intake pipe... what to do..????
2.. there is also another line coming from the wastegate... what to do..... any help would be appreciated...
Why dont you just drive around with "Im a Knob" sticker on your window.
Dose pipe and sticker have the same affect.
There is a small difference between the two Dave.
the sticker actually has people questioning whether its a piss take or not.
dose pipe confirms it without a shadow of doubt.
Edited by Swiper the Fox
that one going to the throttle is your bov recirc which you dont need to worry about block it off, the one going to the rocker cover is the oil breather you must have that so make a nipple on your new intake pipe and the vaccum one goes into the t peice of the stock boost controoler you can block it off
Hope you enjoy stalling and backfires....Sorry ash
if u do it correctly this will not happen, i had a metal "dose" pipe made for my 34, i removed all the piping for it from above the turbo (sorry i dont know the mechanical name but it was 1 black pipe and 1 steel/alloy pipe" and also blocked out the bov and i never stalled. as for backfiring after i installed my cooler i got backfire a lil bit and i didnt realise an increase
i run a hks ssqv now though so no more dose as i got a bit over it
So what part of your install was done "correctly" over the 100's of others that have issues.
You only have issues when you do it without having the car tuned my car was stalling before I had it tuned then when its tuned for no bov it doenst stall and runs well
I dont know where all these stalling theories are coming from... I blocked off my BOV on my Stagea, no stalling. Had it blocked off on my 33 and.......... no stalling???
Only side affect was a nice flutter sound thru gear changes and backing off!
If the dude likes the sound let him have it ffs....
Yes there is knowledge backing up the fact that it can hurt your car, There are also people who have done it and never had a problem.
Like the sound? Do it, its easy as hell.
Dont like the sound and think its stupid close the thread and move on.
Trouble is we get absolutely inundated with threads like this all the time...Rice modifications all aimed at getting a certain sound or certain look only...Quite often sounds and looks that make 'all' of us targets of the law...This pisses me off!!
Now if we don't at least make an attempt to quell threads like this by using deserved words such as knob etc, imagine how ricey SAU will become!!! 2 out of 3 threads will be titled "How do I make my Skyline sound / look like a 14yo really did design it??"
So maybe relax a bit on the people making their thoughts on ricey mods known because ricey mods make us all targets...If you dont like people doing this, close the thread and move on...
:) Feeling better now...
btw Tututuriffic thread guys!!!
One thing I did notice when I stuck a Mount Franklin lid in the BOV return on my S15 to get this 'hectik dose' was that the boost gauge would maintain a positive boost reading between gears...I notice with BOVs active, the gauge returned to 0"hg....
Edited by NSNPWR
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
    • You just need a wheel alignment after, so just set them to the same as current and drive to the shop. As there are 2 upper links it may also be worth adding adjustable upper front links at the same time; these reduce bump steer when you move the camber (note that setting those correctly takes a lot longer as you have to recheck the camber at each length of the toe arm, through a range of movement, so you could just ignore that unless the handling becomes unpredictable)
    • I got adjustable after market rear camber arm to replace the stock one's because got sick of having to buy new rear tyres every few months. Can anyone please let me know what the best adjustment length would be. I don't have the old ones anymore to get measurements. I'm guessing the stock measurement minus a few mm would do it. Please any help on replacing them would be fantastic I've watched the YouTube clips but no-one talks about how long to set the camber arm to.
    • Heh. I copied the link to the video direct, instead of the thread I mentioned. But the video is the main value content anyway. Otherwise, yes, in Europe, surely you'd be expected to buy local. Being whichever flavour of Michelin, Continental or Pirelli suits your usage model.
