  • Replies 119
a new wife?
Dunno what sort of wives you go for TiTan. 250kg, I'd be expecting 2 for 1.
I'd want at least 3 or 4 I think to total 250kg :down:
he is getting a boz special, they weigh the same as 3 but you only get 1.
Drat! You found me out :cool:
My wife wives super-secret-stealth-ninja-surpise-package is at the brisbane depot, I pick it up this arvo :rolleyes:
good stuff. they make a good track car. I've driven and worked on/built a few 80s alfa's over the years. including some GTV 2l and GTV6 models. they have good balance with the rear mounted transaxle and have some other cool features too like inboard brakes. I would suggest building it to a class as there is lots of cheap door to door racing to be had in various historic classes.
but if you just want a track monster for fun then go ahead. :rolleyes:
I have raced a Group NC alfa in nsw historic touring cars and it's great. makes over 200hp from it's 2l engine running 50mm carbs, big cams, carrillo rods, etc. :cool:
they are great cars but full of rust. I read your first posts about "not much rust" and thought to myself.... just wait till you start taking it apart. sure enough, rust everywhere. comes with the territory but not too bad if you get on top of it quickly.
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
