I tell you guys what IS the absolute best set of wheel nuts (sick aint it :happy:) I've ever seen or used, and that's Project MU's.
If money is no object (and this is beer money for you guys), I can't recommend anything more than these. They're steel, but of a hollow design so they are still light, and they have a captive washer on them so they don't bind.
We use these on Mark's R34 time attack car, and although the wheels have been on/off literally hundreds of times, they're good as new. Got them from Racer Industries on the Gold Coast.
From memory they're around $300 per set. I'll get these next, as they've proven themseves to me as good economy. (Drip a little oil between the washer and the nut itself prior to first use, just as you would tightening head studs, they torque up beautifully)
This is the type we use;
http://www.project-mu.com.au/en/products/o..._nut_racing.php
I have some of these & would recommend them above any alloy nuts.
It is pretty simple - you don't want them failing. You don't want to have to worry about them failing. YOu don;t want to have to continually replace them.
On that basis they are actually pretty cheap. Light too for that matter.
  • Replies 50
that's me. i just cant bring myself to pay $400 for wheel nuts. i understand the economy argument, but yes i'm a tyt arse!
If you check the obvious import sites you should be able to get them for less than $250.
Also Nismo make steel wheel nuts in various lengths. they don;t appear to have the little collar on them like the project mu ones, however.
can't seem to find any project mu stuff less than the $390 price, any suggestions?
Mine never failed but damaged the thread both on the nut and the stud, it got so bad that I had to replace my studs
same here. studs damaged due to the soft alloy thread coming apart and mashing the stud thread. pita. got to watch them closely and clean as you go all the time. a damaged stud can ruin your whole championship (i carry a bunch of spares now..!)
thanks for that but nothey are not the correct ones.
these are the ones
Yeah sorry I realised after i posted them, I thought I had seen them on there before for around the same price.
no worries. i think i found some decent ones (aussie made i think) through meridian motorsport, $150/set. apparently quite good i will report on them soon.
bit late....but anyway, I gave up on ally wheel nuts after stripping one. Don't need that sort of issue.
The ones I have run for years are steel from my mates at autobarn. take a nice thin 17mm socket and fit in most wheels. they have a flange so they don't slide into the deep sockets. look like this....thanks ascii art.
. __
\___/
I don't have an issue with using a rattle gun to spin the nut if you have long studs, but always stop early and finish them by hand with a torque wrench (unless the rattle gun has actually been calibrated to the right torque, 110nm for standard studs). I have seen studs stretch and break from not torquing right, it is just crazy not to take the time to do this stuff right on a track car. I use a makita electric impact wrench then finish off with a warren and brown torque wrench, does not take too long.
  • 3 weeks later...
I was just told something very interesting relating to annodised alloy parts. I was explaining the problem (stripping a lot of these wheel nuts) and his first question was "what colour are they"........ They have all been red, and he went on to say that annodising them RED has a weakening affect on them. Something to do with the process of annodising them RED whereas other colours didnt have the same problem! (to the same degree) he had some hardness numbers to back up what he was saying. So that's interesting, anyone ever heard this?
My red ones are also stuffed!!! I don't remember what brand they were but I bought them for $120 a set so definitely not the top shelf ones. Also bought some black ones from ebay, metal nuts that you tighten with the allen key. The centre of the nut rounded making some of them useless. I think its best to spend more front up and don't have to worry about it...
I tell you guys what IS the absolute best set of wheel nuts (sick aint it :D) I've ever seen or used, and that's Project MU's.
marlin is on the money with the project mu nuts. they are teh shit. the rays daytona ones i sold to ant are just as good too and are my favourite nuts. not nearly as hairy as marlin's are and screw heaps better too.
you may find the rays ones a bit cheaper than the pmu ones. I certainly don't think I sold ant his for anything like $400....
for those on a budget I use the plain, open ended but high quality (brand name) steel nuts. they are very strong and quite cheap around $30 per set of 4. will last forever if treated right. the high quality alloy nuts are better than the cheap ones. some even use an heli-coil like insert for the thread but none are as good as the top quality steel ones like the pmu or the rays daytona.
these are the budget option:
Work also make nuts that look identical to the rays ones pictured above and again reasonable in price.
Finally discovered these (for those that want alloy):
They are about $100/set of 20, apparently locally manufactured using 7075 alloy.
ZERO issues with these, they have been faultless.
FWIW I tried those cheapie D1 nuts you see everywhere and they were no good after ONE wheel change, they stretched even at 108Nm. Junk.
    • I know why it happened and I’m embarrassed to say but I was testing the polarity of one of the led bulb to see which side was positive with a 12v battery and that’s when it decided to fry hoping I didn’t damage anything else
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
