  • Replies 81
james that sucks!!! did you get your money back at least??? well it was good seeing you all. car has gone to the auto elec today and he is working on it tonight.. wish me luck!!!
yer i know =( yer got the money back. good luck with your car!
Thats silly. Organiser should have been more organised!
they have done this heaps of times, never been a problem, to point the finger at Ray and the crew isnt right.
cops were there at the last one, they just hang around westal road and go people being stupid, and there was more people there then.
friday was cold and wet still a big turn out but there have been bigger, cops are just using their anti-hoon bullshit in anyway possible.
being a blitz weekend also, cops are just getting a bit to big for their own shoes lately.
if they hung around for a bit they could see for themselves it doesnt need to be controlled, common sense and courtesy when maneuvering the cars in the street make these Dyno night run smooth.
filth i couldn't make it stuck at work :ninja: ,did the nur get a run? if it did what he get out of it?
Nathans nur? It ran around a 214awkw or something like that, he was on the dyno straight after my run.
they cancelled it coz the red commo did a burnout and someone call the cops....
everyone one does the right thing then some idiot ruins it for everyone. isnt that just the story of our lives!!!!!
Yeap it sure did. Dunno if thats the true power but I know with a power fc, cam gears and more boost it can become 300+ so we will see :thumbsup:
^ seems as though the dyno was reading low. But of coarse that means nothing because a dyno can be made to read what ever you want. All of my friends cars read 15-25kw less than what they have on previous dyno's
Specifically the '86 which ended up making less power than the last RE dyno night even though it had more modifications.
Im still happy with the way my car went though. 138.9kw from a VH45 with filter and NICO ecu only. I was very suprised with how loud it was on the dyno too haha.
Its a bit sad though that the 4.5lt v8 only makes 8kw more than my E15 pulsar on the same dyno lol
I agree...i wasted my money to pay for that shit....got approx 50kw less than my previous dyno....my car did 267 rwkw....and at RE it only read 197 awkw...70kws u loose from a rw dyno to aw dyno? dont think so....
Lol yea I had 275.6 on a few dynos but rays seems to think I have 232kw
man those cops were seriously f**kheads I dont understand what theyre on these days those blokes. and that stupid woman.
they were yelling out to us telling us that 'all these cars are illegally parked blah blah'...so we wondered wtf is their problem these days?
they also thought they were pretty smart and happy to let us know that 'we could give out quite a few defects here i reckon'....
seriously if a freaking dyno night has to be shut down for god knows what reason whats next?
its not the first time, the springy motors dyno night was also shut down for no apparent reason a few months ago too.
i really just dont understand cops these days.
its as if they need to feel they have power to make up for the respect they keep losing every day. and also to get back at those who bullied them in their high school days.
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
    • Do you have some data like fuel pressure? It's really hard to say if you're still fighting a fuel system issue at this point. Could be something weird like the FPCM dipping out.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
