Gav - if you sourced the car from the UK it'd be RHD wouldn't it?
Just a thought..
True, however UK cars are a heap more expensive due to their initial import tariffs, and smaller market compared to the rest of Europe.
Fellow over here bought a 1999 M3 BMW (LHD) last month with 25,000 kms for 20,000 Euro. I had a drive and it feels like it goes bloody hard, although couldn't do too much on the icy roads!
Hey Gav
How about something a little Italian? Maybe a Lancia Delta HF Integrale Evoluzione II?
http://www.supercars.net/cars/1993@$Lancia...ione%20IIg.html
Or maybe stay Jap and see if you can pick up an R33 Autech 4-door from Prospec Motorsport Co. in the UK (http://www.prospec-ms.co.uk/)
Or even a Nismo built R34 GT-R V-spec Nur:
http://www.gtr.co.uk/html/shownews.asp?ID=.../forsale_281203
The Audi A8 sounds nice though, or maybe one of the high powered BMW (Alpina, Brabus) or Audi (RS) Estate wagons. Or what about a little Lotus Esprit Turbo (or Lotus Turbo Esprit?). There's also the Lotus Carlton - they're a bloody weapon, and although they didn't get released in RHD (as far as I'm aware), one of the Williams Renaults wouldn't be bad. An older car might be a Fiat Dino V6 (same engine as the Dino 246 but with an iron block).
1989 Lotus Carlton:
http://www.supercars.net/cars/1989@[email protected]+Omegag.html
1995 Lotus Esprit S4s:
http://www.supercars.net/cars/1995@[email protected]%20S4sg.html
1995 Audi RS2 Avant:
http://www.supercars.net/cars/1995@$Audi@$...2%20Avantg.html
2001 Sportec RS4 Biturbo Level 2 (outta reach but till awesome):
http://www.supercars.net/cars/2001@$Sporte...Level%202g.html
2001 Renault Cli Sport V6:
http://www.supercars.net/cars/2001@$Renaul...Sprt%20V6g.html
Cheers
Brendan
Gav, Steve is working on a couple Lotus's at the moment, let's just say there a tad underpowered, and constantly having problems, not my choice.
A tad underpowered??
I don't think so Annie!
Those Lotus Esprit V8 twin turbos are very very powerful and very quick!
And they are very very sexy looking cars :P
Hows-a-bout a BMW AC Schnitzer. Similiar to an m3 but has been worked on by Schnitzer- sorry to state the obvious. There is also a BM where the shove the M5 engine into the M3 chassis and then upgrade the brake suspension etc. Perhaps someone could help me with the name?
Either on of those Go hard.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
