well maccas is down the road they can cook breakfast :yes: or someone can use the kitchen and cook something
are you staying at best western centretown or Best Western A Trapper's Motor Inn
  • Replies 566
I did promise Neil that I would try to make this day...
Turbo is on now :rofl:
7 weeks to go...
Still need to;
1/ Redesign AFM to Turbo pipe.
2/ Change all fluids/filters
3/ Find and replace gearbox (broken 3rd gear is no good)
4/ Buy some tyres... costly bit
5/ Engine tune
6/ Wheel Alignment
7/ Fit Second seat/harness
8/ Fit Oil Cooler
9/ Repair body damage (good chance this will be left out, lol)
Think that's it... lol, should be easy working 6 days a week... bring on Sunday's!
You know whats funny Dan,,,I won't be there,,,I'll be at Phillip Island. So SAU expects YOU as a driver trainer,,,just no Drift training tiger.
If you have forgotten how to drive straight,,,put Liz in the passenger seat,,,. I rate the girl!!!.
Cheers
Neil.
Just paid :)
Full Name:Jason Swavley
Car Type:R34 - GTT
Newb or not:Noob only done 1 track day
Most recent lap time if not newb (can be another track if necessary but make sure you mention which one):1.22
# of Drivers:1
# of Passengers & Name: 1 - Antonia Glezakos
Cheers
Neil.
Lol, well I'll see how we go mate, got a fair bit to get done, including some body work. Is there rules against running without a front bar?
Cheers
Neil.
drive straight into a paddock that is.
soo. i am thinking of making my exhaust consist of two hotdogs and no large mufflers, should sound pimpin. will bring the large muffler that makes it street legal spec too incase its too loud for the track.
Am thinking of just going down to spectate, if any one in western sydney needs tyres or anything taken down for the day shoot me a pm and ill be happy to help out since there will be uber room in the wagon...
Liz, You're on, we can compare notes while we wait to be pulled from the kitty litter.
This exhaust should be easily legal for the track, I have a Turbo back 3 inch system with no mufflers or hot dogs or cats or anything and it scrapes in for legal. (Also have a 3lt bottom end with lots of torques just like you :sick:) As for on the road to and from the track... could be touch and go, I would guess over if you were tested... however it should be noted that most cat back 3 inch skyline systems fail when correctly tested.
Have a good day and Stay Sidewayz Kidz,
Dan.
PS. Sunday tomorrow and we are off looking for gearboxes...
I'm cruising down to spectate as well, but I'm not sure if I'm taking the LOLvo or cruising down with my sis in her Spazda3. I'm not entering my car because the clutch has been playing up quite a bit since Texi.
+1 Passenger.
# of Drivers: 0
# of Passengers & Name: 1, Jonathan Welsh.
Can't see my name on the list, realised i forgot to mention my payment description: reaper1721 wakie. payment would have cleared 24th of may.
Whens the next list update?
EDIT: woops, on mates account. :)
Edited by mark.k92
If the VL has all its panels at that stage, and a new fuel pump, then I'll load her on the trailer. It will be the slowest car there though, RB30E with an auto and open diff.. Still, no reason not to have a bit of fun before the big build goes ahead.
Plus I'm sure everyone will have a good laugh seeing a commodore out there getting its ass kicked.
You'd be suprised. Last year at OP South someone brought a $200 VP wagon (or similar) along to the track and did considerably better than alot of the Skylines on the day.
Then again, the gearbox was leaking oil and large chunks of metal at the end of the day :)
    • jeebus. glad you weren't under it while performing the stunt. Also thanks for the link to the wheel measurer, exactly what I needed
    • In the older stuff there were very significant differences 2wd to 4wd, for example Stagea had strut front end for 2wd and double wishbone for 4wd so it was not minor to swap. From poking around the 2wd v37, it *looks* like it might be more possible; some of the parts specifically have "2wd" stamped on them which suggests the platforms are more similar. You'd still want to start with a 4wd half cut to swap stuff from though. I'd suggest if you don't have a tune on the ECU you don't really need one on the trans either. Throttle mapping is in the ECU side (and you can always use a Roar Pedal if you want the throttle to actually respond to your foot), and really if you are happy with the stock power you probably accept the stock trans behaviour too....its all made to be "sporty" not racey.
    • So, updates. I have not washed the car since it came back from Tassie. I've driven it around a bit but not got around to actually sorting it out. I DID raise it because I cracked the rear bar leaving a hotel which was very distressing. Interestingly, the car drives more compliant now that it's raised a fair bit (5mm front, 15mm rear). Also noticed that my FR height was 10mm lower than FL. So that's now sorted out, too. I also bought this and had it printed: https://www.etsy.com/au/listing/1576422240/wheel-and-tire-fitment-tool-universal?ref=shop_home_feat_1&dd=1&logging_key=08f604d9fa4cc383550ba985e6ac85cd5cac7fbb%3A1576422240 Now, if I was smart I would have taken my brake calipers off to actually use this correctly but it was evident enough to me that in the region where the caliper was... there was nothing to hit suspension/guard/arm wise. So I'm going with "it'll be fine" after using the tool to hopefully very precisely measure the wheel clearance. Also while doing this, I had the very VERY bad idea of jacking one of the wheels/suspension arms up while the rest of the car was on jack stands. I did this to see how the arm would travel. This all was well and good until the car slid off the stands and went through a fence. So don't do that. Incredibly nobody was hurt and there was only minor damage to the rear bumper as the car didn't have far to slide, and had 3-4 wheels on it. The only damage turned out to be the fence itself which was easy to fix, and a little bit of damage to the fibreglass rear bumper trim. I had already planned to try a touch up paint kit to fix the time I drove into my garage door to see if it'd help in the interim before I get it fixed properly. I used the Dr Colorchip kit after looking online and seeing everyone talking about it. Yes it's made for chips and not huge broken missing pieces and I'll be 500% recommending it for stone chips after using it for stupid things like me. This took about ... 10 minutes and looking at the half assed photo the 30 second job I did on the bumper corner was almost perfect just by using the tiny little brush and painting it in. The sealact stuff to remove over-painting is really useful, so if/when I do it again I'll likely slather the touch up paint well over it and then clean it up with the cleaning solution. The wheels should arrive in a couple of weeks. I am still kinda confident after doing a stupid amount of measuring (and borrowing a set of 18x10.5+15) that they will not fit because I overlooked something, somehow and flew too close to the sun. ALSO R34 GTR guard liners do not fit on a GTT. I bought the undertray brake duct guides and had the wonderful problem of them not fitting my intake, my oil cooler and the liners themselves were even worse. Attempting to fit them won't work in general - You would have to cut them up as another poster mentioned as the bodywork is different on the GTT. At least I can try to resell them. So instead of cutting those up, I cut up my old already-cut-up GTT liners and extended them by using some PP plastic and drilling some 8mm holes for some nissan clips for the 'extra' bit. Because I was happy to cut them I was able to mount them pretty damn forward so I now have some semblance of guard liners, and the brake vents seal the bumper from the bottom. It sort-of-looks like this, to give some idea - If you look at the GTR and then the GTT this is when I realised that I needed to seriously measure as the inside of the rim area is entirely, entirely, entirely different and could not take any internet measurements for granted.
    • If you are Ecutek tuned then these TCU tunes are anywhere from $550 to $700 usd. If you are not ECUTEK tuned, then it gets costly!
