Will be running the same setup as before. There was a T88 kit advertised on here a while ago but i never heard anymore about it.
Id say it will make a little more power as having more oil pumping thru it should make things spin freely. lol
Will be looking into E85 so probably need to get bigger injectors and another pump...
Think it was a T88-38GK kit but im sure the 51 will do the trick.
No E85 at pumps here. Probably wont be for another few years. lol
My tuner gets E85 by the drum so will just get him to stock up. He runs a 400+rwkw RB25 in a 32 circuit car.
So who is going to jump in and get the 3.4 kit..?
spools rb34 stroker kit is finaly on sale
http://www.spoolimports.com/content/SPOOLN...TROKERCRANK.asp
price is $5500
test car makes 608hp at 8000rpm on 23 psi with a to4z
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
