yeah, it should have been cheaper. needless to say, i worked for an independently owned station, where government legislation was more of an "option" than "mandatory". :)
Edited by pyro-ns
  • Replies 62
yeah, it should have been cheaper. needless to say, i worked for an independently owned station, where government legislation was more of an "option" than "mandatory". :D
:P
As opposed to the "big guys" who seem to dictate their own rules to the government :D
hahahahaha, you just made me think. when the 10% ethanol blend came to QLD, the servo that i was working at was one of the first 6 or so to get it. the price was the same for the ethanol blend as it was for regular 91 unblended. a customer came in one day and said, "Isn't there meant to be no tax on the ethanol blend, so it should be about 8c cheaper?" i had to stifle my laughter and tell him that government tax is somewhat higher than 8cpl.
They may have been thinking of the 8cpl subsidy the QLD govt used to do. In practise however, the servos in QLD pretty much set the prices about the same as other states and pocketed the extra 8cpl.
You're obviously referring to govt excise, which is much higher as you said.
I'm a bit twisted.
Today the servo price billboard had no prices so I stopped and went in.
"Because you are making such big profits, petrol is free today"
I am still going to where she told me, but its getting very hot.
You are a very mature, thoughtful and insightful person Hugh.
Oil companies and governments don't like you. :blink:
Is the P-P-P-P going to underpin its platform by advocating the removal of speed humps (- and put chicanes in instead)?
We know what heavy braking, alternating with changing down and accelerating does to fuel consumption. :sick:
Bloody petrol!
I need shares in the stuff as I'm current burning 18L per 100km ...
I thought I was bad at 16per.
Lucky I have a 25G,N/A to run around in now.
The RS4 has been on jack stands for 8 weeks. The longer it is there the more money I save.
HMMM,But all that rego and insurance money is going to waste. :blink::sick::D:):down: :down:
A while back there was a sign on a bowser, "Not paying for petrol is stealing" Some sage had written underneath, "So is a
$1.65 a litre.
THAT is gold, Hugh! If you ever find out who did it, shake their hand for me please!
Hi
My beef with the price changing is.
They get a tanker in at the start of the week say and haven’t sold all of it by the end of the week why does the fuel price change from mid week to weekend. Isn’t that like price gouging shouldn’t the price stay the same until all of the first tanker has been sold on.
Phil
    • Ok I get you. But isn’t the butterfly intake a headache with the +T?  see this is my plan so far but please advise me into the right direction.  Nistune Ecu, 1000cc Bosch injectors, TD05 or TD06 Kinugawa turbo using stock rb25det exhuast manifold, walbro fuel pump unsure of model I think it’s 450/460, spitfire coils and sparks to suit and a R35 MAF sensor and boost sensor.    I was thinking maybe do a cheap eBay plenum $400-500 or try find a stock det neo intake. I think I’d port match it so it’s getting the full capacity but open to advice please.  Thanks
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
